89 yj - 396 bb - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 12th, 2012, 10:47 AM   #61
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
I wish I would have seen this 6 months ago:
http://www.joegibbsdriven.com/traini.../compcams.html
All About Zinc
Recently there has been quite a lot of talk about ZINC, so we’re going to explain why that is as well as the difference it makes during break-in.
The word is out regarding the reduction of Zinc in today’s motor oils, but there is a lot more to the story. Specifically, not all Zinc additives and high Zinc content oils perform the same. Here are four facts related to Zinc. First, the oil additive generally referred to as Zinc is technically Zinc Dialkyl Dithiophosphate (ZDDP). As stated in the book Lubrication Fundamentals,” In heavily loaded applications, flat tappet cam followers operate on partial oil films at least part of the time. Lubricants with anti-wear additives are necessary if rapid wear and surface distress are to be avoided. oil additive Zinc Dithiophosphate is to provide anti-wear activity for the camshaft and lifters."
Second, Zinc (ZDDP) is not a lubricant until heat and load are applied. Zinc must react with heat and load to create the sacrificial film that allows Zinc to protect flat-tappet camshafts and other highly loaded engine parts.
Society of Automotive Engineers’ Automotive Lubricants Reference Book states, “ZDDP is the predominant anti-wear additive used in crankcase oils, although it is a class of additive rather than one particular chemical. Sensitivity of the additive to commence giving anti-wear protection varies inversely with the thermal stability of the additive.”
As a result, the third fact is that not all Zinc (ZDDP) additives react under the same level of heat and load. Zinc has different “Burn” rates. Some Zinc additives have slower “burn” rates that require more heat and more load to activate than other Zinc additives. For example, Passenger Car Motor Oils (PCMO’s) typically feature a faster burning Zinc than Diesel Engine Oils due to the lower compression ratios found in gasoline engines compared to compression ignition diesel engines. As a result, not all “High Zinc” oils have the same activation rate. Joe Gibbs Driven BR Break-In oil uses a “Fast Burn” ZDDP that activates quickly. Fourth, detergent additives “compete” against Zinc in the engine. Detergents are additives that clean the engine, but detergents don’t distinguish between sludge, varnish and Zinc – it cleans all three away. The “old school” theory on engine break-in was to run non-detergent oils, and this allowed for greater activation of the Zinc additive in the oil. Joe Gibbs Driven BR Break-In oil features a low detergent formula to allow the “Fast Burn” Zinc additive package to activate faster and to full extent.
Characteristics of Zinc and Detergents determine how quickly and to what extent an oil will provide sacrificial boundary film protection for your engine.
In order to achieve seamless protection for your flat-tappet camshaft or highly loaded engine, you need to establish the presence of the correct “Burn Rate” additives on the surface of the camshaft, lifters and other highly stressed engine parts. A properly matched set of assembly lubricants and break-in oil is of high importance.
Using Unmatched Lubricants - Additive Clash:
Old April 14th, 2012, 01:08 AM   #62
frdboy
frdboy's Avatar
Spent the evening working on this again, got the cam installed, valves adjusted and motor put back together. We did find one more issue, the freeze plug behind the cam was installed to deep. The cam was pushed up against it and rubbing. we knocked it out and FF is going to source a new plug.
I installed a Lunati VooDoo cam 213/219 @ .050 .515/.530 lift
It had a comp. 268H, 218/218 @ .050 .485/.485
Old April 14th, 2012, 09:27 AM   #63
Shotgun
I only wheel with boats.
Shotgun's Avatar
That's going to sound wicked!
Old April 16th, 2012, 09:50 AM   #64
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
John- I gots a little gift for your motor......
After installing that bad boy you might be able to keep up a little better this season. You might even take me!~
Old April 18th, 2012, 08:27 AM   #65
FORD FLARESIDE
just hockey
You have me intrigued young man.
Did you get me a Blue Oval Badge to attach to the motor?
..........FYI, if that blue grating doesn't work for you, I can pick up a sheet of expanded metal this week at Central Iron. I think I saw a 4x4 sheet down there the other day.
Old April 18th, 2012, 08:34 AM   #66
FORD FLARESIDE
just hockey
I know Adam is a friend, and my appreciation to his help is huge.............and with all that being said...............Adam is meticulous when putting an engine together. He definetly has an eye for detail. Even the Silicone was perfect that he layed out.
His focus was amazing considering all the distractions he could have had Friday night.
We are lucky to have his wisdom in our club, and on this site for that mater.
Oh, and the new freeze plug is in, headers are on, and the YJ will be rolled back into the Barn tonight to start installation.
Old April 18th, 2012, 10:51 PM   #67
FORD FLARESIDE
just hockey
A few more pictures.
Old April 19th, 2012, 11:05 PM   #68
FORD FLARESIDE
just hockey
Well, the motor is in, Kind of...............
Old April 20th, 2012, 06:22 AM   #69
Should be fun. First outing is when??
Old April 20th, 2012, 06:37 AM   #70
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Jeep blessing :fingers crossed:
Old April 20th, 2012, 07:35 AM   #71
FORD FLARESIDE
just hockey
The timeline is definetly going to be tight, but my plan is to drive it to the Blessing of the Jeeps.
Old April 20th, 2012, 11:08 PM   #72
FORD FLARESIDE
just hockey
Tinkering tinkering tonight,.................just couldn't get motivated.
Tried some relective paint with the air brush on the two pullies. Looks wierd when you hit it with the camera flash.
Old April 23rd, 2012, 11:10 AM   #73
FORD FLARESIDE
just hockey
In a round about way, I ended up scoring a set of 36 x 15.50 x 15 MT MTZ's.
I plan on putting them on the Bead locks for the trip to the Blessing.
Old April 24th, 2012, 10:56 PM   #74
FORD FLARESIDE
just hockey
................lost the stupid throttle spring for the Holley somewhere
Who carries Carb parts in Grand Rapids?
Old April 24th, 2012, 11:05 PM   #75
Tacker
Tacker's Avatar
Port City Racing in Coopersville .
Old April 24th, 2012, 11:07 PM   #76
FORD FLARESIDE
just hockey
I'll have to head over there after work, Thanks
Old April 24th, 2012, 11:15 PM   #77
Tacker
Tacker's Avatar
I may have one. Let me look tomarrow before you buy one .
Old April 24th, 2012, 11:18 PM   #78
FORD FLARESIDE
just hockey
I am coming into Muskegon tomorrow night, I could stop by.
Old April 26th, 2012, 09:48 PM   #79
FORD FLARESIDE
just hockey
Picked up the new shoes today...........they are just a little bigger then Mickey's that came with the Jeep.
Old April 27th, 2012, 08:41 AM   #80
I really like the look of the MTZ's
Page generated in 0.32511 seconds with 83 queries
