How To Remove Detroit Lockers from D30/35? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 25th, 2011, 01:01 PM   #1
hobbyjeep
Default How To Remove Detroit Lockers from D30/35?
I purchased a YJ a few years ago that has Superior Super Axles (30 spline) and Detroit Lockers in both axles. I would like to make it a better daily driver and want to remove the Detroit lockers - at least in the front axle. Because these are 30 spline hardened axles, what is the cheapest option to replace the Locker with something less aggressive like a lunch-box locker. I don't want to go back to an open differential, but I don't enjoy driving as it's currently built. I'm running 35 inch tires so need to keep the 30 spline hardned axles.
Looking for ideas how to remove the Detroit Lockers making it a better daily driver while keeping my 30 spline hardened axles. Thanks
(Sorry, this is also listed under "Jeep Tech")
hobbyjeep is offline   Reply With Quote
Old November 25th, 2011, 01:05 PM   #2
Andy456123
Guest
the detroits are going to handle better than lunchbox lockers, and be stronger and quieter. Sounds like you want a limited slip or a selectable locker up front. I don't know if there is a TrueTrac for 30 spl dana 30s - that would be the best mix of better traction, on-road handling, and cost.
Or bite the bullet and get an air activated locker like an ARB or Zip, or electric selectable like the E-Locker.
Andy456123 is offline   Reply With Quote
Old November 26th, 2011, 10:08 AM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
For the front, you're stuck with the Detroit, Zip Locker, ARB, or E-Locker (don't recommend that one).
For the Rear, there's the Grizzly, Zip, Detroit, ARB, or Ected.
Page generated in 0.18603 seconds with 32 queries
