trailrail 2.0 EB build.... - Page 9 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 11th, 2012, 11:09 AM   #161
Strangler
Strangler's Avatar
Actually, no. Post 'em here.
Old October 17th, 2012, 10:25 AM   #162
trailrail302
Im going FAST!!!
trailrail302's Avatar
Its not much but its progress!
Frame rails are started.
trailrail302 is offline   Reply With Quote
Old October 17th, 2012, 09:53 PM   #163
Strangler
Strangler's Avatar
Those engine mounts look vulnerable to heat.
Old October 17th, 2012, 10:23 PM   #164
Bones
Bones's Avatar
and moisture.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 18th, 2012, 10:32 AM   #165
trailrail302
Im going FAST!!!
The top section (green section) are made from the latest HV9147 spec qualifications and heat resistant to 2,300 degrees. Should be no problem
Originally Posted by Bones View Post
and moisture.
Moisture factor is still in R&D but again should be no problem.
Old October 18th, 2012, 12:02 PM   #166
Strangler
Strangler's Avatar
Sweet table.
Old November 21st, 2012, 08:36 AM   #167
trailrail302
Im going FAST!!!
Big thanks to Alumcj from Motor City Machines for helping me out last night. I had some 2" 1/4 wall tubing to bend and Alumcj helped me bend it since I did not have a 2"die. Bending this stuff is sketchy for sure, infact we actually broke the die doing it. luckily it was in a reapairable spot and everyone was OK when it happend.
I will say its not a good feeling when the bender says KABOOOM....
We also cut out some brackets and frame gussets.
This build is stuck in slow motion but its better than no motion....lol
Thanks again Mike!!!!
Old November 21st, 2012, 10:00 AM   #168
Mr.Green
I can levitate!
Mr.Green's Avatar
2" x 1/4 wall???? Is this going to be a military grade buggy with armor and stuff? Geez.
Old November 21st, 2012, 10:49 AM   #169
trailrail302
Im going FAST!!!
theres only two tubes that will be 2" the front and rear cross member that the lower links mount to. Also the rear trailing arms everything else will be 1 3/4 120 wall.. well aside from the actual box frame thats 3/16 she will be a piggy... oink oink
Old November 24th, 2012, 11:11 AM   #170
trailrail302
Im going FAST!!!
Measuring for and ordering my 30' radiant tube heater tomorrow..
It will be nice and cozy building the Derailed Bronco this winter.
Old November 24th, 2012, 12:18 PM   #171
Strangler
Strangler's Avatar
That will be sweet in your shop!!
Old November 24th, 2012, 02:12 PM   #172
osweezea
If you're up for some reading, this may help you out. But it sounds like oyu may have a bit of this experience available through others. Good luck.
http://www.jeepforum.com/forum/f9/cj...hread-1364193/
Originally Posted by trailrail302 View Post
Anyone on here good at fiberglass work? I need some help making a fiberglass mold, these will be big molds for bedside/fenders. any help would be great! even just some tips would be good I have not messed with fiberglass that much. I want to make prerunner fenders and bedsides. there is one company that makes some but I dont like them at all. plus the bedsides are stock size and I want to stretch this around 20"
Plus if I make a mold If I rip one off I can just make another. I have searched every way possible. even fabing ranger bedsides but nothing will get me exactly what I want unless I custom make them myself.
osweezea is offline   Reply With Quote
Old November 26th, 2012, 08:38 AM   #173
Mr.Green
I can levitate!
Mr.Green's Avatar
Please dont encourage him.
Old November 28th, 2012, 09:48 AM   #174
trailrail302
Im going FAST!!!
Had the day off yesterday and I was able to get some quality time with the bronco since the wife and kids were gone all day...
Frame Gussets
Inside of frame
Outside of frame with gussets
I had to clearance teh frame for the power steering pump
Old November 28th, 2012, 11:14 AM   #175
Mr.Green
I can levitate!
Mr.Green's Avatar
Already having to hack it apart to make stuff fit. JK, its looking good Diner!
Old November 28th, 2012, 03:13 PM   #176
trailrail302
Im going FAST!!!
Thanks Green, heres one more.
Old November 28th, 2012, 03:22 PM   #177
boggin-machine
boggin-machine's Avatar
looks like it will be sweet!!!
Old November 28th, 2012, 07:56 PM   #178
trailrail302
Im going FAST!!!
Thanks, I will check it out!
Old December 6th, 2012, 08:24 AM   #179
trailrail302
Im going FAST!!!
Trying to figure out what muffler to run. I have only ever had Flowmaster in the past and I think I want a change. any suggestions? I will be running the drivers side looped back to the front of the engine and it will cross over to the passanger side and run back as one. Engine is a blown 4.6 3 valve. Im thinking a Borla XR1 or a magnaflow?? Any Ideas of what would be a good sounding muffler for this set up, I know this will be a loud set up but I want to try and keep it as quite as possible....
Old December 6th, 2012, 08:37 AM   #180
buttercr125
I work out
buttercr125's Avatar
How quiet do you want it? Dynomax make some nice mufflers that are kinda quiet but still flow nicely and give you decent sound. I have all kinds of info on Dynomax, FloPro, Flowmaster and just about any other muffler. Borla is about the only manufacture that I can't get a good price on. We will have to get together one night after work or the weekend and I can take a look at what you got. Would Tuesday work for you?
Tags
meballs
Page generated in 0.43046 seconds with 84 queries
