trailrail 2.0 EB build.... - Page 43 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 22nd, 2014, 09:22 PM   #841
I'm always interested in free shit.
Old August 23rd, 2014, 12:02 PM   #842
1%er problems
Old August 23rd, 2014, 12:34 PM   #843
trailrail302
Im going FAST!!!
trailrail302's Avatar
Originally Posted by 1TFROT View Post
might be able to help you with that if you're interested.
im interested...
trailrail302 is offline   Reply With Quote
Old August 23rd, 2014, 02:39 PM   #844
Originally Posted by trailrail302 View Post
im interested...
Hey back off sonny.
Old August 23rd, 2014, 06:56 PM   #845
1TFROT
1TFROT's Avatar
im interested...
ford or chevy (sorry, didn't feel like going back to look )
d60 I assume?
1TFROT is offline   Reply With Quote
Old August 23rd, 2014, 07:08 PM   #846
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I recommend this setup
sbcrichie is offline   Reply With Quote
Old August 23rd, 2014, 07:28 PM   #847
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Is that a solid round, tapped on both ends?
Old August 23rd, 2014, 07:34 PM   #848
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
yes that one is. the ram was mounted high on that axle, I like the tie rod to be mounted under the highsteer arm for double sheer but woudnt work on that rig because of where the ram was mounted.
edit no its not solid bar it was thick wall dom I tapped threads in.
Old August 24th, 2014, 08:23 AM   #849
trailrail302
Im going FAST!!!
d60 I assume?
Yes Ford Dana 60...80-90 kingpin.
I appreciate your help, Thanks
Old August 24th, 2014, 08:29 AM   #850
trailrail302
Im going FAST!!!
I agree, I really like the double sheer setup. It helps spread the load over the knuckle too. I ordered artec's arms which are basically the same design as the ones you posted above. I think I will be happy with this set up.
Old August 25th, 2014, 10:05 AM   #851
Mr.Green
I can levitate!
Mr.Green's Avatar
Pretty sure if you are not mounting the tie rod in double sheer (under the high arm), connecting the two steering arms does little to nothing.
Old August 25th, 2014, 10:12 AM   #852
Bones
Bones's Avatar
pretty sure if the vehicle doesn't have a functioning suspension or drivetrain, steering is not an issue
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 25th, 2014, 10:31 AM   #853
1 ton tj on 40's
1 ton tj on 40's's Avatar
Old August 25th, 2014, 10:39 AM   #854
trailrail302
Im going FAST!!!
you are surely one to talk... and yes steering does matter now because I need to have the steering ram in place when I build out the top part of the chassis and mount radiators etc..
Old August 25th, 2014, 11:06 AM   #855
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
I've learned one thing from this thread...buy it done...less time...less hassle....less money
Old August 25th, 2014, 11:32 AM   #856
trailrail302
Im going FAST!!!
would have been done by now if a certain friend kept his word..
Oh and please show me where I can buy a EB tube chassis, built the way I want it, that is cheaper. Ill gladly go buy it done...
Old August 25th, 2014, 11:34 AM   #857
jeepm715
DEAK Racing
jeepm715's Avatar
Blue Torch Fab Buggy - Great Lakes 4x4. The largest offroad forum in the Midwest
Will fit bronco hood
jeepm715 is offline   Reply With Quote
Old August 25th, 2014, 11:37 AM   #858
trailrail302
Im going FAST!!!
Originally Posted by jeepm715 View Post
as much as I like your chassis it doesn't work for me, needs more room in the back for the rear seat.
Old August 25th, 2014, 11:57 AM   #859
trailrail302
Im going FAST!!!
mine will be mounted between the highsteer and factory arms for double sheer.
Old August 25th, 2014, 11:57 AM   #860
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
you don't think connecting the two steering arms helps spread the load from the top of the knuckle to the lower half of the knuckle? me thinks it does
Tags
meballs
Page generated in 0.45544 seconds with 85 queries
