trailrail 2.0 EB build.... - Page 12 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 18th, 2012, 07:20 PM   #221
chevotass
chevotass's Avatar
awesomeness
Old December 19th, 2012, 08:44 AM   #222
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I should have my shifter available, i ended up buying this to use instead.
http://www.speedwaymotors.com/Economy-Shifter,1928.html
I have one of those on my shelf Im not using
Old December 20th, 2012, 12:57 PM   #223
trailrail302
Im going FAST!!!
trailrail302's Avatar
Cool, let me know what you need for it.
Are you going to greens party next Saturday? if you are headed this way and can bring it with you I can pick it up at the party.
Thanks,
I think I already know this answer but...It will work with the 4r70 extension housing on a non clocked 205 right?
trailrail302 is offline   Reply With Quote
Old December 20th, 2012, 01:16 PM   #224
IDK-I know the bolt threads are the same I believe that hold it to the ext. housing. But as far as distance between the bolt the tcase IDK. Its just the shifter not the linkage from shifter to tcase.
Iwon't be making it east, but I could put it in a usps flat rate box and just pay the shipping and its yours..probably like $12 or something of that nature.
Old December 20th, 2012, 01:28 PM   #225
trailrail302
Im going FAST!!!
Is it a single shifter or a twin stick set up? I can pay shipping no problem. I know there was talk of some other west siders coming over for the party, maybe it can hitch hike a ride with them..lol eitehr way no big deal.
Thanks again,
Old December 20th, 2012, 01:42 PM   #226
Ill take a pic of i have available when i get home.
Old December 20th, 2012, 02:04 PM   #227
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I can bring it back with me if that helps?
Old December 23rd, 2012, 08:40 PM   #228
one 40 yr old shifter.
Old January 7th, 2013, 08:17 AM   #229
trailrail302
Im going FAST!!!
Got some work done this week end, built the eninge mounts. and just about done with the trans/transfer case crossmemeber and mount.
Old January 7th, 2013, 09:26 AM   #230
Strangler
Strangler's Avatar
Well those auttaaa do it. Looks nice.
Old January 7th, 2013, 09:43 AM   #231
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
you should see what we did the front axle!!! Can you say a-arm dana 60?
Old January 7th, 2013, 10:16 AM   #232
trailrail302
Im going FAST!!!
The only down side of these mounts compaired to the factory aluminum mount is the top brace sits up higher making it impossible to slide the manifold off the studs, so I will have to remove the manifold studs and use bolts instead.... OR, the studs are pretty long, I could cut the stud down to allow the proper clearance. I only need about 1/2" off the stud.
Old January 7th, 2013, 10:30 AM   #233
Bones
Bones's Avatar
cut the stud down. In my experiance, they hold better than bolts, unless you get locking bolts, or wire them.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 7th, 2013, 11:01 AM   #234
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
I've had good luck with bolts and regular lock washers with my headers. 25k on my dd and no leaks so far.
Old January 7th, 2013, 12:34 PM   #235
bbaXJ
Yooper In Training
bbaXJ's Avatar
Looking good!
Old January 9th, 2013, 06:31 PM   #236
Mr.Green
I can levitate!
Mr.Green's Avatar
This whole thing is getting built around the parts im using and everything will be "serviceable" and I gaurantee at the end of the day I will be able to access, service, repair and remove parts a lot easier than you can from your Jeep.
0 for 2.
JK, Dineur. Its looking good. Cant wait to see the RCR suspensionon that buggy mobile. I <3 U.
Old January 10th, 2013, 10:40 AM   #237
trailrail302
Im going FAST!!!
Originally Posted by bbaXJ View Post
Looking good!
0 for 2.
Thanks Guys.
Oh and I cut 1/2" off the studs, all is good so green your ticker of 0-2 is debatable...lol
Old January 10th, 2013, 07:38 PM   #238
Mr.Green
I can levitate!
Mr.Green's Avatar
Im watching you!
Old January 14th, 2013, 08:30 AM   #239
trailrail302
Im going FAST!!!
Still thinking of ways to support the heavy pig, I think I will keep the trans solid mounted with tube bushings on the crossmember at the frame in the same plane with a poly engine mount. Add a rear output support with a tube bushing for the 205 and off the side of the tcase I plan to run a toque bar down to the crossmember to help with addidtion toque load. Any suggestions or thoughts for running this set up? I dont know if having the tube bushing centered under the tcase (and solid mounting the trans with the bushings on the crossmember at the frame) will create any problem since it is out of plane from the other bushings. I dont want to run into a problem down the road snapping the extension housing.
Any how here is my home made knock off TMR bracket for the tcase support, this will run down to a tube bushing.
Old January 16th, 2013, 07:58 AM   #240
trailrail302
Im going FAST!!!
Tags
meballs
Page generated in 0.60180 seconds with 84 queries
