trailrail 2.0 EB build.... - Page 11 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 10th, 2012, 10:37 AM   #201
Mr.Green
I can levitate!
Mr.Green's Avatar
Of course!
Old December 10th, 2012, 01:12 PM   #202
Bruster
beer is good!
Old December 11th, 2012, 05:34 PM   #203
dudekcj7
rev limiter racing
dudekcj7's Avatar
If you haven't decided on a muffler the dynomax ultraflows work really well sound great and flow like crazy. You can get 3 and 3 1/2 inlet/outlets in a 6" round stainless version and up to 4" in the welded ones.
dudekcj7 is offline   Reply With Quote
Old December 11th, 2012, 05:43 PM   #204
trailrail302
Im going FAST!!!
trailrail302's Avatar
Thanks, I have not decided as of yet. I was thinking either magnaflow or dynomax. I will look into the ultraflows.
trailrail302 is offline   Reply With Quote
Old December 11th, 2012, 05:47 PM   #205
dudekcj7
rev limiter racing
dudekcj7's Avatar
Thats what i put on my cj7 5.3 with 2 into 1 love the sound.
Old December 11th, 2012, 10:17 PM   #206
chevotass
chevotass's Avatar
but is the 6" round forestry approved? when i was searching for a muffler most of the round ones were straight thru mufflers like the deisel mufflers. that would not pass the stick test as a forestly approved muffler. at least that was my understanding.
Old December 12th, 2012, 09:11 AM   #207
trailrail302
Im going FAST!!!
Thanks to an awesome tech write up I seen on pirate, last night I converted my 205 to a twin stick set up. It was very easy to do and took very little time. And the cost to convert the actual case was $0.00. Everything bench tested good. Hopefully it all works the same under power.
Only problem now is I need to get two stock shifters, anyone have any stock 205 shifters laying around?
Old December 12th, 2012, 09:19 AM   #208
I might have mine left over. I did the same to my case a couple weeks back. Really is simple isn't it? With my case clocked and now twinstick modded i am not 100% sure how i am gonna do the shifters yet. If i don't end up using it ill let you know.
Old December 12th, 2012, 09:20 AM   #209
dudekcj7
rev limiter racing
dudekcj7's Avatar
I never thought about the stick test when i put the dynomax on but i have never been turned away at a park.
Old December 12th, 2012, 09:21 AM   #210
trailrail302
Im going FAST!!!
yeah I was surprised on how easy it was.
I put up a wanted thread too. but let me know if you dont use yours
Thanks,
Old December 12th, 2012, 10:52 AM   #211
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
From michigan.gov for Silver Lake State Park
(a) Vehicles shall be equipped with a muffler and spark arrester containing baffles, shall meet the muffler and spark arrester requirements specified in subsection (g) of section 81133 of Part 811, Off-Road Recreational Vehicles, of the Natural Resources and Environmental Protection Act, Act 451 of the Public Acts of 1994, being Section 324.81133 (g) of the Michigan Compiled Laws and shall successfully pass a muffler and spark arrester baffle test. A vehicle shall successfully pass a muffler and spark arrester baffle test by preventing passage of a flexible, plastic rod,no larger than 3/8-inch in diameter, through the muffler and spark arrester when inserted through the exhaust outlet and/or visual inspection.
(b) A maximum noise level of 94 Db(A), or the current EPA emissions limit, shall be met. The testing provisions of current SAE J 1287, June 93 standard for ATV and motorcycle vehicles and SAE J 1169, March 93 for all other vehicles shall be followed and all vehicles shall pass a stationary sound level test. The stationary sound level test shall be administered from a 0.5 meter (19.69 inches) distance at one-half the engine's maximum rated RPM and as further described by current testing provisions for the particular vehicle.
A flow through muffler will not only fail the stick test, but probably also the sound portion as well.
Edit: I've asked before and a piece of window screen does not qualify as baffling. They check this by pushing/pounding pretty damn hard to make sure your baffling is permanent
Old December 12th, 2012, 10:58 AM   #212
bigbchevy
missmrgreenagain
bigbchevy's Avatar
i like the spintech or whatever they are mufflers . its what i have on my 5.0
H.o.r.e
Old December 12th, 2012, 05:11 PM   #213
bbaXJ
Yooper In Training
bbaXJ's Avatar
Silver Lake sure isn't very strict about it though, I've been there in some pretty loud vehicles and had friends in even louder ones and none of us have ever been questioned.
Old December 12th, 2012, 05:25 PM   #214
trailrail302
Im going FAST!!!
my last buggy had the stick test and a des test. at silver lake but that was the first year tehy started never had anything since.
Old December 17th, 2012, 09:28 AM   #215
trailrail302
Im going FAST!!!
What did you buy yourself for Christmas this year???
Here is my gift to myself
Old December 17th, 2012, 09:29 AM   #216
bigbchevy
missmrgreenagain
bigbchevy's Avatar
very nice dj
H.o.r.e
Old December 17th, 2012, 09:31 AM   #217
trailrail302
Im going FAST!!!
Originally Posted by bigbchevy View Post
very nice dj
Thanks, this should get the motivation that has been lost back on track..
Old December 17th, 2012, 09:32 AM   #218
firehawk
Live Action!
firehawk's Avatar
Hell yeah!
Old December 18th, 2012, 08:07 PM   #219
I should have my shifter available, i ended up buying this to use instead.
http://www.speedwaymotors.com/Economy-Shifter,1928.html
Old December 18th, 2012, 08:19 PM   #220
firehawk
Live Action!
firehawk's Avatar
Damn thats cheep. Might have to replicate what you put together.
Tags
meballs
Page generated in 0.31329 seconds with 84 queries
