Starts and stall twice, then starts and runs good - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 25th, 2011, 12:59 AM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default Starts and stall twice, then starts and runs good
1993 Ranger 3.0 4x4 5 speed. When it is cold it starts and stalls out twice, on the third try it starts and idles and runs well.
booblinker is online now   Reply With Quote
Old November 25th, 2011, 02:33 AM   #2
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
I'm curious as my 4.0 does this only when cold. New coilpack, plugs/wires, fuel pump/filter, air filter, injectors, intake gaskets, iac valve, and o2. Still does it. Other sensors test good on my multimeter.
Old November 25th, 2011, 04:19 AM   #3
jaysusr
jaysusr's Avatar
Map sensor?
Old November 25th, 2011, 06:50 AM   #4
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
You try turn the key forward then off then on then off then on? so fuel pump fills lines to full pressure. I had a car that the pump or regulator would leak by and did not hold full line pressure it would start first try after i did this. just a shot in the dark but if it works it might narrow it down some for you..
Edit: didnt see the cold thing. mine did it all the time so may not be the case.
bbrancheau is offline   Reply With Quote
Old November 25th, 2011, 01:07 PM   #5
osteologation
Originally Posted by jaysusr View Post
Map sensor?
Not sure on the 3.0 but I know post 91 4.0's don't have map sensors.
Old November 25th, 2011, 01:13 PM   #6
MilwaukeeF350
Dan
Possible old gas? It been sat for about 1 1/2 year or longer with full tank of gas.
Have you check IAC sensor. My 94 Explorer 4.0L did that at random times it was carbon filled in IAC sensor's port.
Old December 1st, 2011, 10:01 PM   #7
booblinker
Sore and Tired 24/7
booblinker's Avatar
New fuel and seafoam fixed the problem.
Page generated in 0.27958 seconds with 44 queries
