94 explorer rear rotors pads - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 24th, 2011, 09:29 PM   #1
XLJetsFan52
Just a good ole' boy
XLJetsFan52's Avatar
Default 94 explorer rear rotors pads
Doing the brakes on my winter beater. 94 ford explorer. Got the tire off and the caliper. Got the old rotor off and put new one on. The piston on the caliper wont compress anymore tho. Ive tried with c clamp, and vise. Any other suggestions? Tried wd40.
Sent from my Droid using Tapatalk
XLJetsFan52 is offline   Reply With Quote
Old November 24th, 2011, 09:33 PM   #2
XLJetsFan52
Could i need a new piston? Due to over travel? My rotor was about as skinny as a quater, and the pads were way past the squeelers. Just an fyi, i just bought this truck.
Old November 27th, 2011, 12:41 AM   #3
bud_light_zero200
bud_light_zero200's Avatar
Send a message via Yahoo to bud_light_zero200
Caliper might be shot. Is the caliper still connected to the brake hose? Sometimes a collapsed brake hose will keep the piston from pressing back in. Try loosening the bleed screw then take a c clamp to it, if it goes back in, it's a brake hose, if not, buy a new caliper.
bud_light_zero200 is offline   Reply With Quote
Old November 27th, 2011, 11:48 AM   #4
Never_Evil
Rear calipers on Fords need to be turned as they are being compressed. If you look at the piston on the caliper, you will notice the two notches. Any auto parts store should have the compression tool for rent.
Page generated in 0.38035 seconds with 35 queries
