Blue Point Plasma cutter 50 amp with consumables - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 24th, 2011, 11:06 AM   #1
firehawk
Live Action!
firehawk's Avatar
Default Blue Point Plasma cutter 50 amp with consumables
Blue Point Plasma cutter 50 amp with consumables $900 obo
Works great, cuts 1/2".
I am the second owner. It was in a shop before I bought it about 6 years ago and been in my garage since. It works great.
I can check the tag on the back of it for model year but it is about 10 years old as a guess.
Price is firm. These were $3500 new
Old November 24th, 2011, 07:30 PM   #2
itchy
itchy's Avatar
Damn it...You tryin to steal my thunder????
itchy is offline   Reply With Quote
Old November 24th, 2011, 08:23 PM   #3
6boltfreak
6boltfreak's Avatar
Send a message via Yahoo to 6boltfreak
why you selling it.
6boltfreak is offline   Reply With Quote
Old November 30th, 2011, 05:38 PM   #4
firehawk
Live Action!
firehawk's Avatar
Originally Posted by 6boltfreak View Post
why you selling it.
Because I want Itchys machine.
Old November 30th, 2011, 05:39 PM   #5
firehawk
Live Action!
firehawk's Avatar
Nope, so I can buy yours.
Old November 30th, 2011, 06:25 PM   #6
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
I'm tempted to offer my rifle up for trade, but it won't help you if you're looking for another plasma...
check that, it'll probably help you get whatever one you want haha
SlayerXJ is offline   Reply With Quote
Old November 30th, 2011, 06:40 PM   #7
firehawk
Live Action!
firehawk's Avatar
So, you want to buy it?
Old November 30th, 2011, 06:47 PM   #8
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
No cash till i sell the rifle.
Old December 8th, 2011, 08:10 PM   #9
firehawk
Live Action!
firehawk's Avatar
Old December 9th, 2011, 12:12 PM   #10
drgrcr
drgrcr's Avatar
Interested, buzz me when you have time. 989-339-0151 Thanks
drgrcr is offline   Reply With Quote
Old December 30th, 2011, 05:07 PM   #11
firehawk
Live Action!
firehawk's Avatar
Ttt
Old December 30th, 2011, 08:52 PM   #12
roger
roger's Avatar
Send a message via AIM to roger Send a message via Yahoo to roger
i want this but i really need to put cement floor in barn first
roger is offline   Reply With Quote
Old December 30th, 2011, 09:03 PM   #13
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
How much air pressure does it take to run this.
Do you use cylinder gas or just compressed air?
How many CFM if compressed air.
I have never used one of these and want to know?
dougstephvoor is offline   Reply With Quote
Old January 1st, 2012, 11:07 AM   #14
firehawk
Live Action!
firehawk's Avatar
I run it from my compressor but I suppose it can be used with cylinders of compressed air if you have access to them, but a compressor would be best.
I dont know the cfm's needed but will look into it.
Old January 1st, 2012, 11:08 AM   #15
firehawk
Live Action!
firehawk's Avatar
This is a lot cheaper than concrete
Old August 7th, 2012, 09:44 PM   #16
firehawk
Live Action!
firehawk's Avatar
Bump
Old August 7th, 2012, 09:58 PM   #17
Midnight Rider
Would you take anything on trade?
Midnight Rider is offline   Reply With Quote
Old August 7th, 2012, 10:03 PM   #18
firehawk
Live Action!
firehawk's Avatar
What do you have?
Old August 7th, 2012, 10:06 PM   #19
firehawk
Live Action!
firehawk's Avatar
Found this on another site, hurry up before I up the price.
Description:
Ideal for heavy gauge cutting of ferrous and non-ferrous metals like aluminum, stainless and carbon steels. Severs up to 3/4" material thickness. Uses high frequency ARC starting to make jobs easier. Features dual power output—50 amp for cutting thicker metals and 30 amp for cutting thinner sheet metal. Uses clean, dry compressed air for both cutting and cooling. No need for refilling compressed gas cylinders during the job. Air pressure regulator provides an accurate adjustment of working air pressure for the best cut. Fan cooled. Includes complete 18 ft. torch assembly, ground cable and clamp.
Needs new tip.
Product Specifications
Stock # PLASMA230
Name Plasma Cutter, Heavy Duty
Price** $3,641.74
Brand Blue Point
Primary Input, V 220V, Single Phase
Primary Amps 46
Output Amps 30 and 50
Duty Cycle 100% - 40%
Gas Supply Compressed Air - 70 PSI (6 CFM)
Torch Lead Length 18’
Ground Cable Length 18’
Power Cord Length 6’
Dimensions 32" H x 20" W x 24" D
Weight 137 lbs.
1000.00 o.b.o (used)
And mine comes with new consumables
Old August 7th, 2012, 10:15 PM   #20
Midnight Rider
What do you have?
What could you use - mostly Bronco parts all years unless you'd like to trade straight up for a 91 F250
Page generated in 0.36586 seconds with 83 queries
