Anti Theft options - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 21st, 2011, 05:40 PM   #1
scottie
Eye candy
scottie's Avatar
Default Anti Theft options
Since my trailer got stolen, looking at ways to deter thieves more on the next one.
The trailer i looked at today had a Height adjustable coupler on it like this
I could remove the coupler each time, but you could just install a new one or a ring in it's place if you wanted to take it. I think they just hooked up to mine using chains and drove away, so i really need to keep it from rolling.
A lot of people chain their wheels up, but usually you can just change the tire and still find a way to roll with. I have nowhere to attach it to a tree or light pole.
Old November 21st, 2011, 06:01 PM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
This is going to sound stupid, but I think lojack would be your best bet.
@clarkstoncracker
Old November 21st, 2011, 06:03 PM   #3
Mclovin
"The Situation"
Mclovin's Avatar
secure your chains wheels weld a nut on the bottom of a ball and lock that in the hitch... Do a little of everything... the harder they have to work for it the less likely they're gonna take it..
Old November 21st, 2011, 06:12 PM   #4
scottie
Eye candy
scottie's Avatar
Problem seems to be battery life, unless i get a solar panel for it.
Old November 21st, 2011, 06:13 PM   #5
blownexploder94
Todd
blownexploder94's Avatar
Maybe run a chain through the wheels and loop it around the axle. I have seen someone bury a steel I beam with a chain welded to it and lock it to the tongue of the trailer.
Old November 21st, 2011, 06:25 PM   #6
cerial
1200PSIg Double acting
cerial's Avatar
Tree and a chain.
If you have one with a wheel on the tongue you can push the trailer towards a wall or your garage. You will need to pull it back a bit to hook to it.
If you only use it like 2 times a year. Set the axles on blocks and put your tires inside. This will also keep your tires from dry rotting.
Old December 13th, 2011, 11:43 AM   #7
Strangler
Strangler's Avatar
Security lug nuts and chains thru wheels on both sides.
Park it backwards, even if you have to drive on the lawn. Anything to make it harder.
Old December 13th, 2011, 12:27 PM   #8
4Bangler
Jackstand Wheeler
4Bangler's Avatar
I have a POS trailer and I keep a bunch of crap on it....it's safe.
Page generated in 0.16610 seconds with 47 queries
