Best 5th wheel or gooseneck hitch and why? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 21st, 2011, 11:28 AM   #1
PavementPounder
PavementPounder's Avatar
Question Best 5th wheel or gooseneck hitch and why?
Would prefer more "why". Quality or features that others don't have, better platform design, better mounting, etc.
Old November 21st, 2011, 11:59 AM   #2
junk90xj
ALLPRO AUTO
junk90xj's Avatar
b&w hidden ball hitch is what 84scrambler and i have.
they work real nice, allow the bed to be smooth for hauling wood and such.
http://www.apalansing.com/
Old November 21st, 2011, 06:03 PM   #3
Mclovin
"The Situation"
Mclovin's Avatar
he said Fithwheel not gooseneck..
oh though B&W does have their companion fithwheel setup im curious to see reviews on
Old November 21st, 2011, 06:04 PM   #4
PavementPounder
So you just have this with the ball sticking out?
I thought this is what went on top of that, which is still removable in order to have a flat bed bottom:
I used to use the terms "gooseneck" and "fifth wheel" interchangeably. I see now that they are two different configurations. I don't have any kind of trailer yet. This is all just research. I edited the title.
Old November 21st, 2011, 06:17 PM   #5
84Scrambler
Ken is right. I have both the B&W turnover ball gooseneck hitch and the companion fifth wheel. I would not choose anything else. I simply pull the slide pin under the wheel well, pull the gooseneck ball, turn it over, and you have complete use of the bed with no rails, and it takes all of 30 seconds. The companion 5th wheel is great. I can put it in or take it out in about 5 minutes. I have no experience with anything else, but I have no reason to go with any other hitch. It all mounts from underneath and is extremely well built.
PP - Let me know if you want to look at the hitch setup sometime.
Old November 21st, 2011, 06:45 PM   #6
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
If you have a shortbed truck I would highly suggest a 5th wheel hitch that can easily slide back to take tight corners. The one I have you pull a lever out and forward on the hitch and hold the trailer brakes while you slowly pull forward and the hitch will slide back and lock. You do the opposite and it goes back to the original position. It makes fuel stops and getting it backed into tight places a breeze. I will check mine out tomorrow and find put what kind it is. It is the best one I have ever used.
Old November 21st, 2011, 08:06 PM   #7
PavementPounder
Have a longbed.
The Companion posted has a 4" range.
Old November 23rd, 2011, 10:50 AM   #8
PavementPounder
Okay, so who can recommend a place who will give me a good installed price on the bottom half?
Old November 23rd, 2011, 11:01 AM   #9
kickstand
circling the drain
kickstand's Avatar
I have this thingy, but my ball doesn't "turnover" it just drops straight down.
Works great. I think if I were shopping them myself I wouldn't go any other route either.
Feel free to drive 2 miles and come take a look any time. I owe you a strongbow anyway.
Old November 23rd, 2011, 11:24 AM   #10
PavementPounder
Its a little farther than that now that I'm back to work, but I'll keep that in mind for when I make a run back to the house. I went back to the east side to the same place I was at before I left.
Old November 23rd, 2011, 07:34 PM   #11
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
Mark, Jim(fittergirl's husband) and I put one in his Dodge in like 2 hours, and IIRC that included beer time. Nice, simple install. He has the B&W one like above. I think the longest part was making sure we drilled the hole at the right spot. We also put his one in his old Ford.
That white Dodge I bought from you has the rail set up in it, I have never had a problem with the rails getting in the way, just they get rocks and dirt in them if you use your truck bed for that kinda stuff.
You get a new truck or is this for the black Dodge?
2000 XJ with a 3 inch body lift
Tie Dyed is offline   Reply With Quote
Old November 23rd, 2011, 09:04 PM   #12
Bones
Bones's Avatar
call Ironman Offroad. I believe he also sells them and can certainly instal them.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 23rd, 2011, 10:07 PM   #13
84Scrambler
I have the 4" hole saw if you do it yourself.
Old November 24th, 2011, 10:39 AM   #14
PavementPounder
Just doing some planning, that's all. I think I'm going to sell my Range and I haven't decided if I will go with a new one or not.
Old December 10th, 2011, 04:42 PM   #15
gixxer1397
gixxer1397's Avatar
I see a lot of you guys like the B&W set up but is there aything wrong wit the rail type sytems where you can run both the goose and 5th set up ?
gixxer1397 is offline   Reply With Quote
Old December 11th, 2011, 04:07 PM   #16
fittergirl
Bird is my bitch
fittergirl's Avatar
The main drawback for me is that with a rail system the rails stay in the bed, making it harder to load heavy stuff. With the turnover ball you can still get a flat bed in about a minute.
fittergirl is offline   Reply With Quote
Old December 14th, 2011, 07:53 PM   #17
Mclovin
"The Situation"
Mclovin's Avatar
My vote is still for B&W but has anyone heard anything else about this issue ?
and apparently after they added more hardware
Old December 16th, 2011, 05:16 PM   #18
Mclovin
"The Situation"
Mclovin's Avatar
B&W Turnover Ball Movement - YouTube
B&W Hitch Movement 2 - YouTube
nobody has any input on this ?
Old December 16th, 2011, 05:50 PM   #19
Freak
Wheelin the HD
Freak's Avatar
I don't see the problem? Frame flex and bed movement under load is normal. The b&w Bitches are not attached to the bed in any way and the ball in its mount has less play than a regular hitch in a reciever. You might want to watch for cracks in the collar around the ball but if that movement makes you panic sell your truck and buy a microbus.
Personally I think a 5th wheel hitch pulles better than a gooseneck. Most gooseneck trailers are set up to have a kingpin that can be slid in place of the ball reciever. Just make sure the 5th whgrl hitch is rated according to your trailer. I had a bad case of a 16k reece sliding 5th wheel hitch sliding while in motion. But the hitch was way over loaded.
Old December 16th, 2011, 07:32 PM   #20
Mclovin
"The Situation"
Mclovin's Avatar
Just makin sure I dont know a lot about Gn's yet..
as for 5th wheels.. I agree they do seem like they would pull better im just concerned about if i ever have to pull into an uneven area and articulation limitations on the 5th wheel setups
Page generated in 0.40872 seconds with 84 queries
