One sick Sami - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 18th, 2012, 10:12 AM   #41
JACK48461
HEAVY D
just picked up 4 rear tj stock fender flares to open up my wheel wells a little bit should have those on this weekend and get some pics posted of the new motor build
JACK48461 is offline   Reply With Quote
Old January 27th, 2012, 08:38 AM   #42
RossDickman
RossDickman's Avatar
Updates? Pictures?
RossDickman is offline   Reply With Quote
Old January 27th, 2012, 10:00 AM   #43
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
Love the Sami!! My next build will be a Sami.
Old January 27th, 2012, 10:59 AM   #44
JACK48461
HEAVY D
I'll deff take some new pics and get them up on sunday its in peices now still waiting on the trans to come back and debating on if i should cut open the floor to make room for the trans and motor. Or try and stuff it and work in tight spaces i may move the firewall back around were the distributor will be also.
Old January 28th, 2012, 06:10 PM   #45
JACK48461
HEAVY D
Old January 28th, 2012, 06:16 PM   #46
JACK48461
HEAVY D
PICS FROM ABOVE ARE TODAYS PROGRESS I STRIPPED DOWN THE ENGINE BAY TO START CLEANING IT UP. REMOVING THE OLD HARNESS GOING TO WIRE AND REPLACE IT WITH MY OWN.
THESE ARE THE BOXES OF PARTS I'VE ORDERED IN THE PAST FEW WEEKS TO GET THIS BALL ROLLING A LITTLE FASTER. MY CURRENT BUILD COST TO DATE AFTER SELLING OFF PARTS FROM THIS AND BUYING NEW OR SOME (USED) ONES IS $3150 PLUS I HAVE ALMOST ALL THE EXPENSIVE PARTS ALL READY INCLUDING THE PAINT.
Old January 28th, 2012, 06:17 PM   #47
JACK48461
HEAVY D
MY SECURITY SYSTEM LOL "LEAVE HIM INSIDE IT & DARE YOU TO GET IN"
Old January 28th, 2012, 06:20 PM   #48
JACK48461
HEAVY D
MY PAINTER SPRAYED A TEST PANEL FOR ME BC I MIXED THE PAINT MYSELF AT WORK AND NEEDED TO TAKE A CAMERA SHOT TO MAKE A FORMULA INCASE I fukc IT UP AND NEED TOUCH UP LATER. I MADE A GALLON THOUGH AFTER I TOOK THIS PIC AND THE SAMURAI IS TINY SO I COULD PAINT IT OVER TWICE WITH THAT MUCH.
Old January 28th, 2012, 06:36 PM   #49
JACK48461
HEAVY D
I still have to get two more expansion plugs to plug off my pcv valve and breather holes so i can steam clean the motor then put on my new oil pan & oil pan gasket and timing cover gaskets. I'm painting the motor/intake chevy orange then doing wrinkle black on the pulleys valve covers and oil pan. Im doing gloss black engine enamel in the engine bay tomorrow morning and ripping the rest of the harness out of the dash inside the only part of the harness im keeping is for my wipers im keeping the pigtail and the pigtail for the blower motor then ill rewire those into my new harness as i go.
Old January 31st, 2012, 11:43 AM   #50
JACK48461
HEAVY D
STARTED CLEANING UP THE ENGINE BAY AND MAKING UP THE WIRING HARNESS AND NOW THAT IT'S ALL PLUMMED UP I NEED TO GET SOME OF THE PIGTAILS FOR THE LIGHTS. NEXT I NEED TO MAKE MY SWITCH PANEL AND FUSE BOX TO GO BETWEEN THE FRONT TO SEATS AND TRY IT ALL OUT.
Old January 31st, 2012, 11:53 AM   #51
DZWrangler
DZWrangler's Avatar
This is by far my favorite thread, love the color. This might sound like a dumb question but how did you get the frame, rear end, leaf springs, all all of the other components black like that (what did you use).
DZWrangler is offline   Reply With Quote
Old January 31st, 2012, 12:07 PM   #52
JACK48461
HEAVY D
The previous owner did alot of it but the best thing I've found is to use the dupli-color truck bed coating brush it on where you can i get the spray bombs to hit the hard to reach spots. Plus its good and tough and cleans off easy after wheeling.
New tires are ordered i'm going with a 32x11.5r15 telstar mud claw radial's should be in soon & I'm picking up a different 2.8l with only 60k on it next weekend. Figured i cant pass it up for $300 complete w half the miles of the one i already have. Plus this will give me a good core to do a 3.4l stroker to over the summer so its ready to swap by next winter.
Old February 22nd, 2012, 10:01 PM   #53
JACK48461
HEAVY D
not to much progress lately been realy busy but I did start making my dash and center console tonight. Gauges r in place and started to be wired. And the center console is close to finished but needs a little more work before i start installing all my electrical and switch panel into it.
Old February 23rd, 2012, 10:14 AM   #54
JACK48461
HEAVY D
New tires just walked in the door
Old February 23rd, 2012, 10:25 AM   #55
XLJetsFan52
Just a good ole' boy
XLJetsFan52's Avatar
I think your title is perfect for this build thread. My pants are a little stiff now. Lol. Cant wait to see the finished product
XLJetsFan52 is offline   Reply With Quote
Old February 23rd, 2012, 10:43 AM   #56
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
Originally Posted by JACK48461 View Post
Just bought a 2.8l v6 complete w t5 for it will be delivered on tuesday. It wont go in for a while though deff need to find a carb intake for it and some headers and freshen it up a bit before I pull my 1.3 and start fabbing it in.
Is there a difference between the GM 2.8's? I always thought those were the ones to stay away from because they came with a rod hanging out the block.
ckupq is offline   Reply With Quote
Old February 23rd, 2012, 10:58 AM   #57
JACK48461
HEAVY D
It should be pretty sweet all said and done. & as far as the 2.8l goes i've never had an issue using a rear wheel drive cast iron head version . But I heard they've had issues with the front wheel drive alluminum head ones. But that was a camshaft issue not rods as far as everything I know so far. I worked at a parts store for 10 years now and there a decent motor usually only good for 225k though. I did just pick up a new low mile one im gonna use it only has around 60k on it.
Old February 27th, 2012, 08:49 AM   #58
JACK48461
HEAVY D
Gauges almost completely wired new motor stripped down ready to degrease and paint. Once thats painted i have a new oil pan/intake/valvecovers to go on it and im going to freshen it up with all new gaskets. Trans jack just showed up today so this week i will be fabbing it into my floor pan and making a mount for that and lining up my new motor mounts.
Old February 27th, 2012, 09:12 AM   #59
JACK48461
HEAVY D
Old February 28th, 2012, 11:43 AM   #60
JACK48461
HEAVY D
new tires just got mounted and dropped back off will get pics on the sami later tonight.
Page generated in 0.40032 seconds with 84 queries
