Lame ass XJ build. Never going to leave the driveway. - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 19th, 2012, 05:37 AM   #41
John D
John D's Avatar
Originally Posted by xj bmx View Post
Aww crud, as long as it keeps it safe. Whats your pinion angle like?
I'll get a pic of it today.
Originally Posted by hamsmotorsports View Post
Pinion guards are great as long as you dont land on it right and jam it up into the drive shaft tube.
Oh, well wonderful. Have you had this happen? I imagine this thing cracking my center section, or pinion support before the 1/2" ring or 3/8" skid bend up.
The case would crack/break way before this guard bent enough to hit the driveshaft.
Old August 19th, 2012, 11:23 AM   #42
xj bmx
SLAYER!!
xj bmx's Avatar
Send a message via AIM to xj bmx Send a message via Skype™ to xj bmx
Cool, mines at I believe 15* hopefully it's enough to not become, to much of a shovel.
xj bmx is offline   Reply With Quote
Old August 19th, 2012, 01:24 PM   #43
John D
John D's Avatar
Here you go, you will learn to work with it. The real fix is a Tru Hi9, but that's still a ways out for me and my piggy bank :)
Old August 19th, 2012, 08:40 PM   #44
xj bmx
SLAYER!!
xj bmx's Avatar
Wow, it does look like it is a rock magnet/trail shovel.
I do plan on a strange Hi9 with a 35 spline detroit or arb if I find I hate the spool.
Old August 19th, 2012, 08:55 PM   #45
xj bmx
SLAYER!!
xj bmx's Avatar
Picked up a 77 hp44 from midnight Ryder on here. He happened to have a 78 f9" that my buddy needed for his bII also.
Untitled by xj bmx, on Flickr
Old August 19th, 2012, 09:02 PM   #46
xj bmx
SLAYER!!
xj bmx's Avatar
Stopped to check the air pressure before the ride home with the axles, the rear springs hate me haha.
Old August 21st, 2012, 07:51 PM   #47
xj bmx
SLAYER!!
xj bmx's Avatar
Soaking it in liquid wrench for the next few days.
hp Dana44 by xj bmx
Old August 22nd, 2012, 05:34 PM   #48
xj bmx
SLAYER!!
xj bmx's Avatar
So today I power washed the 44, I found some things that sort of scarred me.
I also found out why my pictures have been so shitty, somehow my resolution was turned way down on my phone, so they should be allot clearer.
Untitled by xj bmx
Think this ball joint is from 77?
Untitled by xj bmx
I think I'm going to gusset the Cs, this scares the hell out of me.
Driver
Passenger
Old August 22nd, 2012, 05:40 PM   #49
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
wow this has seen some salty winters.. or boat anchor..fresh metal and it will be fine!
bbrancheau is offline   Reply With Quote
Old August 22nd, 2012, 06:09 PM   #50
xj bmx
SLAYER!!
xj bmx's Avatar
Right?! It's like the original owner had a drive way paved in salt. I may make a truss like gusset at work for them out of some 3/8" steel. Broken Inners is my biggest fear of an axle so who knows.
Old August 22nd, 2012, 08:11 PM   #51
xj bmx
SLAYER!!
xj bmx's Avatar
Maby I can make one of these gussets work for my C's? Haha
Old August 23rd, 2012, 12:52 AM   #52
Fraser
Fraser's Avatar
nothing in that pile looks even close to what youd need
Old August 23rd, 2012, 01:04 AM   #53
xj bmx
SLAYER!!
xj bmx's Avatar
With some grinding I could get them into shape, but I'm going to see if I can use some square tube I have and do what I found on pirate "I'd post just the pic, but Flickr won't accept it.
Aftermarket C`s for the 44 ?? Gusset kits ? - Pirate4x4.Com
post #7
Old August 24th, 2012, 04:33 PM   #54
xj bmx
SLAYER!!
xj bmx's Avatar
So yesterday I got the hubs, spindles and shafts off. Today got some goodies for my 9" and cut the nuts off the ball joints on the front.
Striped.
Pile of scrap.
Instead of fucking with trying to break the nut free, I just cut it off.
Drums, Calipers pads for the rear.
Untitled by
xj bmx, on Flickr
Old August 24th, 2012, 04:35 PM   #55
xj bmx
SLAYER!!
xj bmx's Avatar
Tomorrow I get to pick up the soft lines and caliper bolts.
Old August 29th, 2012, 03:51 PM   #56
xj bmx
SLAYER!!
xj bmx's Avatar
Sunday I finally had all of my rear disk brake swap parts, so I decided to do a little mock up to figure out how all the parts went together. So I put all of the caliper parts together, then put the axle shaft in the vice and tryed to put the disk on the flange only to discover the flange was about .5" larger than the inside of the rotor hat. So confused I mad sure I had the right rotors. But after some googling I found it was a 50/50 of guys that had flanges that fit or didn't fit into an '89 bronco rotors.
So with that information, I decided to bring my shafts to work and turn my flange down to 6.5", well as I was removing the wheel bearings I noticed that both flanges looked different. Well it turns out I was both of the 50/50 flanges, one is 7" the other 6.5"? Tho the smaller one is a press fit, so I will take about 1/16" off that one also.
Large flange
Old August 29th, 2012, 03:53 PM   #57
xj bmx
SLAYER!!
xj bmx's Avatar
Small
Both
Old August 30th, 2012, 11:15 PM   #58
xj bmx
SLAYER!!
xj bmx's Avatar
Pulled the steering and knuckles off today, this truck was seriously neglected. I think i really might just buy some crane knuckles, this I freaking me out.
I definitely am going to be buying two new knuckles from Reid instead of just the passenger, there is so much missing material on the inside of the knuckle I'm surprised it hadn't failed on the truck it came from.
Best Friends
Untitled by xj bmx
Fuck!
Untitled by xj bmx
Time to cut the wedges off and off to sand blasting.
Old September 1st, 2012, 03:17 AM   #59
xj bmx
SLAYER!!
xj bmx's Avatar
Got my flanges turned down, he took 1/32 off the small one and matched the other to that, and added a 45 * chafer on the end.
Untitled by xj bmx
Untitled by xj bmx
It fits!
Untitled by xj bmx
Old September 1st, 2012, 03:19 AM   #60
xj bmx
SLAYER!!
xj bmx's Avatar
I also cut my brackets off when I had a minute with one of my lasers.
Untitled by xj bmx
Page generated in 2.13067 seconds with 84 queries
