Front VS rear trutrac's - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 19th, 2011, 07:11 PM   #1
Torg38
TorgFab
Torg38's Avatar
Default Front VS rear trutrac's
They make front and rear true trac's.....Why What the difference? Can you use them each way???
Torg38 is offline   Reply With Quote
Old November 19th, 2011, 07:13 PM   #2
kj kyle
kj kyle's Avatar
reading this makes my head hurt.
kj kyle is offline   Reply With Quote
Old November 19th, 2011, 09:06 PM   #3
yyj87
yyj87's Avatar
One is built for your Dana 30 and the other for your 8.25?
yyj87 is offline   Reply With Quote
Old November 19th, 2011, 09:08 PM   #4
beejers
always building
beejers's Avatar
they are directional. something to do with the worm gears
beejers is offline   Reply With Quote
Old November 21st, 2011, 12:41 PM   #5
Torg38
TorgFab
Torg38's Avatar
Yep, Just got off the phone with the eaton tech guys. The worm gears are stronger in the forward direction. So for the front design the just install them the other way. Otherwise they are the same. Kinda like how a d30 Hp is stonger then the Lp because of the back cut in the ring gear. Like Duke from GI Joe says..." Knowing is half the battle"
Old November 21st, 2011, 12:49 PM   #6
Not sure in off road usage, but in the drag world, it seems the quality of them is worse in the last few years due to manufacturing changes. Lot of people are killing the 9" units.
Old October 27th, 2014, 06:36 PM   #7
Bo's Cj 7
Bo's Cj 7's Avatar
Anybody know much about the detroit truetrac I just purchased one
used. Summit states ford so I assume setup for front anybody have any other info on these things? Can the worm gears be moved from one side to the other if need be or does it really matter
http://www.summitracing.com/parts/dtl-913a589/overview/
Bo's Cj 7 is offline   Reply With Quote
Old October 28th, 2014, 08:41 PM   #8
trl4x4
trl4x4's Avatar
Ran one in dana 35 for a few years till it exploded! worked great,called them on it they said i should nt of installed in the 35 due to axle flex. What the ....?
trl4x4 is offline   Reply With Quote
Old October 28th, 2014, 09:14 PM   #9
Wramblerguy
Wramblerguy's Avatar
My understanding was that the rear was a little more aggressive
3rd generation jeeper
Old October 28th, 2014, 09:42 PM   #10
davidkassie
davidkassie's Avatar
I had a true trac in the front of my truck.. 8.5 10 bolt. Came out of a rear end only a few months old.. under heavy traction neither front tire would spin while the driveshaft was.. ideas?
davidkassie is offline   Reply With Quote
Old October 29th, 2014, 03:16 PM   #11
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
That part number is for a D44 rear, you'll want the 913A592 for the front.
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old October 29th, 2014, 03:22 PM   #12
Bo's Cj 7
Bo's Cj 7's Avatar
They are all gears as far as I know so I would have to say something is broken.
I will have to disassemble this one to take a look to see if anything could be turned around or move side to side to make a difference. This will be installed in the front of a V-8 Tj with dana 44, but the part number comes back to Ford does not say front or rear but ford hasn't put a 44 in the rear since late 60s I think. This is new and the manufactures date was april 2014.
I have a true trac in the front of my Cj and love it, it has been in for 3 years now with no issues, this other one is for a buddy
Old October 29th, 2014, 03:26 PM   #13
Bo's Cj 7
Bo's Cj 7's Avatar
I have this one could the worm gears be moved from one side to the other or does it really make much difference? I guess that is the question
Old October 30th, 2014, 10:54 AM   #14
Bo's Cj 7
Bo's Cj 7's Avatar
(My Question to Eaton/Response below): I have a Detroit True Trac part # 913A589 it has been in the rear axle (little fib) of my jeep and has worked great, it is time to do some up grades and I would like to install this in this front. The info I have states this is for rear operation. Will this work in the front can I or should I swap the gears from one side to the other? Thank you for any info, this is a great differential.
BrentABussell@eaton.com
11:46 AM (4 minutes ago)
I do not recommend either and it would be best for you to buy the correct unit for the application. That being said I have had people who have done it both ways with no issues.
Brent Bussell
Customer Support
Technical Specialist
Phone# (800) 328-3850
Direct# (248)226-6762
Fax# (248)226-6740
Old October 30th, 2014, 03:40 PM   #15
Jeeperz Creeperz
GL 4x4 Vendors
I guess it would depend on where you looked up the application My information just shows "Dana 44 rear".
Old October 30th, 2014, 07:16 PM   #16
Wramblerguy
I have a front for sale...
Page generated in 0.33312 seconds with 71 queries
