No particular rhyme or reason, a 99XJ build - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 30th, 2012, 07:20 AM   #81
Offroadian
seasoned
Nice work.
Offroadian is offline   Reply With Quote
Old May 30th, 2012, 07:56 AM   #82
Modestmar00Xj
Show me the trails!
Modestmar00Xj's Avatar
Send a message via AIM to Modestmar00Xj Send a message via Skype™ to Modestmar00Xj
wow thats all i can say! wow! This might be the first XJ that you can sell for over 10,000 bucks! awesome work!
Modestmar00Xj is offline   Reply With Quote
Old June 1st, 2012, 11:04 PM   #83
Asher
Jack stand wheeler
Asher's Avatar
Worked on the rear axle tonight. Added a fill hole for the diff fluid that should make filling it a lot easier.
Kind of pointless to make filling it easy if its still a pain to drain it so added a drain plug.
Also added some tie down points to make strappingthe xj to the trailer a bit quicker.
Added a upper truss as well I'm not sure why but it can't hurt.
Asher is offline   Reply With Quote
Old June 2nd, 2012, 09:00 AM   #84
Offroadian
seasoned
Axle looks awsome.
I like the tiedown feature.
Any problem with heat warpage?
Old June 2nd, 2012, 09:16 AM   #85
Asher
Jack stand wheeler
Asher's Avatar
Originally Posted by Offroadian View Post
Axle looks awsome.
It moves around as you weld, just went slow and moved around a lot to keep it straight.
Old June 2nd, 2012, 11:00 AM   #86
John D
John D's Avatar
Axle looks awsome.
Worrying about keeping the axle perfectly straight is overrated.
X2 on the tie-down, nice touch.
Old June 2nd, 2012, 01:28 PM   #87
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Axle looks good.
Old June 4th, 2012, 09:33 PM   #88
Asher
Jack stand wheeler
Asher's Avatar
Stuck the axle back under it so I could start to figure out where the shocks are going to go. Then on to closing all the open space back in and add some tube around the wheel wells.
Old June 5th, 2012, 02:07 PM   #89
gofast
Nice work on that 9. Looks really solid.
gofast is offline   Reply With Quote
Old June 5th, 2012, 03:09 PM   #90
jerm97xj
I fixed it!!!
jerm97xj's Avatar
I freaking dig it man!
jerm97xj is offline   Reply With Quote
Old June 7th, 2012, 06:04 AM   #91
kmanxj5011
kmanxj5011's Avatar
you keep amazing me on this!!! Definitely jealous of your fab skills!!
kmanxj5011 is offline   Reply With Quote
Old June 7th, 2012, 03:06 PM   #92
Asher
Jack stand wheeler
Asher's Avatar
Nice work.
Thanks
I doubt it but thanks
Originally Posted by RDK_YJ88 View Post
Axle looks good.
Thanks
My luck it'll bend first time out.
Thanks
Thanks
Old June 7th, 2012, 05:39 PM   #93
cannaert
No more Jeep
cannaert's Avatar
Damn, I am digging all the fab work you have done. I dont think your going to mess up that rear axle at all.
I like your rocker fix. I need to do that to mine sometime soon.
Old June 7th, 2012, 06:59 PM   #94
Bruster
how much for a set of ubolt elimitnators? haha
Old June 18th, 2012, 09:53 PM   #95
Asher
Jack stand wheeler
Asher's Avatar
Started the rear bumper. First up made some tow points, they go 10" back into the frame and use four 5/8 bolts each and two of the factory bolts per side.
Angled the ends to help clear the spring shackles.
Added a receiver to the bumper as well.
Then started on the tube for the wheel wells.
Old June 18th, 2012, 10:44 PM   #96
cj7on44's
cj7on44's's Avatar
Looking pretty sick jay
cj7on44's is offline   Reply With Quote
Old July 16th, 2012, 09:51 PM   #97
Asher
Jack stand wheeler
Asher's Avatar
Found some time to get a few more things done on the XJ .
Finished up the tube around the rear wheels and tied it into the bumper and the spring mounts.
Now I need to pull it back off and finish welding it up.
Old July 16th, 2012, 09:57 PM   #98
Asher
Jack stand wheeler
Asher's Avatar
And it looks like ill be stretching the front end at least 3" to make some room for the tires they will be hitting the front of the rock sliders . So I guess I get to three link the front sooner rather than latter.
Old July 16th, 2012, 09:59 PM   #99
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Looks nice! I like it.
*2007 Rubicon
*2006 Duramax
Old July 16th, 2012, 11:03 PM   #100
cj7on44's
cj7on44's's Avatar
Looking awesome jay
Page generated in 0.57371 seconds with 83 queries
