No particular rhyme or reason, a 99XJ build - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 17th, 2012, 06:11 AM   #41
John D
John D's Avatar
Looking good, I love the detail you put into your work.
I've been staring at this pic trying to figure out what's going on, but I can't see it. It looks like you cut the bottom of the door off then added another piece just like it. It's probably just the angle, but I don't get it.
Originally Posted by Asher View Post
Old March 17th, 2012, 06:38 AM   #42
Asher
Jack stand wheeler
Asher's Avatar
That's the door cut down 1.75" capped welded up and sanded.
another pic of it.
This is the added piece.
Asher is offline   Reply With Quote
Old March 17th, 2012, 06:48 AM   #43
Asher
Jack stand wheeler
Asher's Avatar
I forgot to post a few pics of how I did the rocker replacements.
I had to make a few cuts to fit it tight to the body. The tapped hole is for the stock seat belts bolt. Also drilled a hole for locating the rear seat.
Old March 17th, 2012, 07:30 AM   #44
I like the rockers.
Old March 17th, 2012, 12:05 PM   #45
John D
John D's Avatar
This is the pic I needed to see it correctly, thanks. Its a good idea.
Old March 20th, 2012, 06:11 AM   #46
Asher
Jack stand wheeler
Asher's Avatar
Made a little progress on the frame last nite.
Old April 4th, 2012, 04:06 AM   #47
cj7on44's
cj7on44's's Avatar
Looking good jason. Can't believe I'm just now finding your thread.
cj7on44's is offline   Reply With Quote
Old April 4th, 2012, 09:19 PM   #48
Asher
Jack stand wheeler
Asher's Avatar
Striping the under coat off the frame can only be topped by removing the stock mounting brackets as worst part of the build process. Cut some more sheet metal out of the way and removed the stock spring hangers. Primed and ready the stiffeners to be welded in.
And since I was already making a mess I sanded the 9" down so I could start picking away at welding my truss from ruff stuff on.
Old April 5th, 2012, 05:23 AM   #49
John D
John D's Avatar
Are you going to shave the 9"?
Old April 5th, 2012, 05:39 AM   #50
Asher
Jack stand wheeler
Asher's Avatar
I'd like to but I'm running out of time on this so that will be a project for another day.
Old April 5th, 2012, 06:21 AM   #51
John D
John D's Avatar
It's pretty easy to do, and a lot easier to do before you put it all together.
Judging by the work you are doing I'm sure you have the tools right there. It would only take you a couple hours at this point, just something to think about.
Old April 5th, 2012, 07:24 AM   #52
Asher
Jack stand wheeler
Asher's Avatar
Looked at the links in your build and at what you did. I think I will give it a go.
Old April 5th, 2012, 08:51 AM   #53
John D
John D's Avatar
You'll be glad you did
Old April 7th, 2012, 01:41 AM   #54
Asher
Jack stand wheeler
Asher's Avatar
Made some more progress on the frame stiffeners.
Old April 7th, 2012, 01:45 AM   #55
cj7on44's
cj7on44's's Avatar
Looking good. Is it going to be ready for July?
Old April 7th, 2012, 01:48 AM   #56
Asher
Jack stand wheeler
Asher's Avatar
Got the ubolt eliminators machined up still need to weld them to the perches.
Then started shaving the 9" cut a small hole to start... sort of
Old April 7th, 2012, 01:49 AM   #57
Asher
Jack stand wheeler
Asher's Avatar
If you come and help..... Maybe.
Old April 7th, 2012, 01:51 AM   #58
cj7on44's
cj7on44's's Avatar
Haha once I'm back on days all ya got to do is ask and I will stop by and help
Old April 7th, 2012, 01:53 AM   #59
Asher
Jack stand wheeler
Asher's Avatar
Looks like its gonna take a little time to make the truss fit right .
Old April 7th, 2012, 01:53 AM   #60
cj7on44's
cj7on44's's Avatar
Those ubolt elimanators look sweet.
Page generated in 0.46511 seconds with 83 queries
