No particular rhyme or reason, a 99XJ build - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 24th, 2011, 08:45 AM   #21
robbietap
Nice work!
robbietap is offline   Reply With Quote
Old December 24th, 2011, 08:46 AM   #22
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Nice work on that front bumper. I'm not a big fan of the look of stingers, but that is a very nice execution...the aesthetics work well.
Craig
Old December 24th, 2011, 09:31 AM   #23
Cool parts peddler
Ironman Offroad's Avatar
USE .250 WALL 2x6 TUBE!!!!!!!!!!!!!!!
Lay the 2x6 flat and it will help protect the doors and handles.
You will bend the thinner tube and the doors will not work.
Mine bent and now the b post has compressed at the bottom. I cannot get the front door back on unless I pull the slider down on a frame rack.
Great job!
Nice clean build.
Old December 24th, 2011, 01:04 PM   #24
John D
John D's Avatar
USE .250 WALL
X2 - I've never been sorry I used 1/4" for mine, I know lots of people who are sorry they didn't.
Old December 24th, 2011, 01:11 PM   #25
4x4klein
Weapon K
4x4klein's Avatar
My thoughts exactly!
4x4klein is offline   Reply With Quote
Old December 24th, 2011, 10:31 PM   #26
Asher
Jack stand wheeler
Asher's Avatar
Red face
Great job!
Nice clean build.
I plan to have supports running from the rockers to the frame, after I weld some HD engineering frame stiffeners on. The supports will be angled and then covered in in 1/2" UHMW to help with distribution of impact and sliding off rocks. I plan on tying the cage into the rockers and supports as well. But nothing is set in stone I'm open to changing it up if this isn't going to work.
Asher is offline   Reply With Quote
Old February 14th, 2012, 12:12 PM   #27
Asher
Jack stand wheeler
Asher's Avatar
Well I broke my hand so progress has been a bit slow.
Test fit the doors after cutting 2" off the bottom of them.
Decided to add some tube to protect the doors some.
Try to get the other side wrapped up this weekend.
Old February 14th, 2012, 01:06 PM   #28
caveman
GeoDude
caveman's Avatar
keep going! me like!
Old February 14th, 2012, 01:31 PM   #29
92FleXj
stacks stacked on stacks
92FleXj's Avatar
Nice work
Old February 14th, 2012, 02:24 PM   #30
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
That looks good I like the way the tube wraps all the way around.
bbrancheau is offline   Reply With Quote
Old February 14th, 2012, 02:56 PM   #31
kmanxj5011
kmanxj5011's Avatar
got pics of the doors after cutting?? did you have to weld them closed? add material?
And got any pics before burning the tube in?
I've got some 2x6 that i am going to replace my rockers with, but i am not sure how high i want to go.
kmanxj5011 is offline   Reply With Quote
Old February 14th, 2012, 04:42 PM   #32
John D
John D's Avatar
Looking good. I have been thinking adding tube to my rockers too.
Old February 14th, 2012, 05:07 PM   #33
Asher
Jack stand wheeler
Asher's Avatar
It opens a section about the length of the door 1.75" wide. I closed it using some .032" thick sheet metal that I bent a 90 degree half inch lip on. This way I had a nice radius to fill to as I welded the bottom of the door skin to the patch piece. I didn't take any pics of the process on the passenger side doors but I'll grab a few as I do the drivers side.
I went as high as I could without having to start doing major reworking to the doors. You could probably go an 1" higher and completely replace the bottom of the door and keep the windows still retracting all the way.
Old February 14th, 2012, 09:00 PM   #34
kmanxj5011
kmanxj5011's Avatar
Sweet thanks! You have a pic before square tube going in?
Old February 15th, 2012, 07:00 AM   #35
Asher
Jack stand wheeler
Asher's Avatar
Old February 15th, 2012, 09:31 AM   #36
kmanxj5011
kmanxj5011's Avatar
NICE!!! thanks.
Old February 15th, 2012, 10:53 AM   #37
jerm97xj
I fixed it!!!
jerm97xj's Avatar
I will be doing this to my Heep sometime. The bottom of my doors are going and the rockers are going (rusting). Thanks for the good info and pics.
jerm97xj is offline   Reply With Quote
Old February 28th, 2012, 05:01 PM   #38
tyler5904
growing xj
tyler5904's Avatar
Can you please post a couple pix of the bottom of the sliders and how you tied them in to the floor thanks. Btw awesome fab work hope mine looks half as good
tyler5904 is offline   Reply With Quote
Old March 16th, 2012, 11:17 PM   #39
Asher
Jack stand wheeler
Asher's Avatar
Wrapped up cutting and patching all the doors.
Old March 16th, 2012, 11:33 PM   #40
Asher
Jack stand wheeler
Asher's Avatar
Dropped the gas tank back out. pulled the 8.25 rear end out of the jeep for the last time. Removed the springs and started cutting off the old spring mounts. I'll be using 63" Chevy springs to stretch the wheel base 5".
Since my frame (sortof) has not enjoyed the rocks to much I started the frame stiffeners. Be doing the inside and outside of the center section.
Page generated in 0.58998 seconds with 83 queries
