No particular rhyme or reason, a 99XJ build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 19th, 2011, 09:59 AM   #1
Asher
Jack stand wheeler
Asher's Avatar
Default No particular rhyme or reason, a 99XJ build
Bought the jeep back in 07 came with a basic budget lift and some 32's.
I carved up the fenders and added some 33" TSL's drove it for a while.
It soon became oblivious I should add some tow points to the front so I built a bumper for it. Wheeled it some more and had fun but the short arm lift brought the suck so I went with a long arm kit from IronRock. Not that it's a bad kit but I now wish I had just built my own. Down the road perhaps.
pic with the lift and bumper.
The Jeep handled much better in the trails and on the road after the lift.
Then I started to get the itch for some bigger tires. I found a 79 d44 with 5.13s and a rear 9" with 5.13s. I removed the stock tubes on the d44 and I'm re-tubbing it with 3"od x .5" wall DOM. Picked up a set of 38.5 TSL's on re-centered h1 bead lock wheels.
I plan on moving the rear axle back 3-5" (see what looks best when I get there) in prep for this I relocated the gas tank.
I wanted to move mine up above the bottom of the frame rails but still mount from underneath.
First I made some room.
Then I bent some 1 5/8 tube and added some sheet metal
I removed the original gas tank mounts from the floor of the cut out section.
welded those to my tube frame for the tank
Added the mounts to hold the original straps
Ended up like this
finished up inside the jeep
Currently I'm adding a winch to the front bumper
then after Thanksgiving at the Mounds the axles, tires, rocker replacement with 2"x6" tube and cage will begin.
Asher is offline   Reply With Quote
Old November 19th, 2011, 10:06 AM   #2
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
I like that gas tank mod.
*2007 Rubicon
*2006 Duramax
*2005 CRD
Old November 19th, 2011, 11:33 AM   #3
kmanxj5011
kmanxj5011's Avatar
What'd you do for the rear shock mounts? I've been wanting to do sonething different since mine broke.
kmanxj5011 is offline   Reply With Quote
Old November 21st, 2011, 08:47 AM   #4
Asher
Jack stand wheeler
Asher's Avatar
I added a 2"x 2" support for my gas tank enclosure My shocks mount off of that. Once I switch to the full width axles I'll outboard the shocks.
Old November 21st, 2011, 09:02 AM   #5
John D
John D's Avatar
I love the tank set-up, but why did you turn it around and run the filler tube out the passenger side? Still using the stock pump/sending-unit? Can you show a pick of quarter panel from the outside where you mounted the filler?
Old November 21st, 2011, 10:54 AM   #6
Asher
Jack stand wheeler
Asher's Avatar
Turning it 180 gave more clearance for up travel when I move the rear axle back. Still using stock pump sending unit. I'll get a pic of the side for you.
edit: You can see it in this shot. Once I have comp cut the rear I will add a fuel door and flush mount it.
Old November 21st, 2011, 11:17 AM   #7
boggin-machine
boggin-machine's Avatar
i like it. one of these days when im in fenton ill have to check it out and lend a hand.
Old November 21st, 2011, 11:20 AM   #8
clarkstoncracker
lol
clarkstoncracker's Avatar
I have to ask... Why didn't you just go with a fuel cell? Your work ended up looking really nice though.
Old November 21st, 2011, 11:41 AM   #9
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
i have to ask... Why didn't you just go with a fuel cell? Your work ended up looking really nice though.
x2
bbrancheau is offline   Reply With Quote
Old November 21st, 2011, 11:44 AM   #10
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Subscribed. Nice work.
Craig
Old November 21st, 2011, 12:08 PM   #11
Asher
Jack stand wheeler
Asher's Avatar
It was a lot of work but I've seen lots of guys have issues with fuel cells picking up the fuel I've never had a problem with a stock tank.
I also didn't want the tank inside the vehicle.
Old November 21st, 2011, 03:09 PM   #12
John D
John D's Avatar
I can't see anything in that pic.
Old November 22nd, 2011, 08:39 AM   #13
Asher
Jack stand wheeler
Asher's Avatar
fixed
Old November 22nd, 2011, 09:12 AM   #14
John D
John D's Avatar
Thanks. I look forward to seeing how you fininsh it. Anything that isn't recessed would be a hazard for being torn off. How big are you thinking for the cut?
Old November 22nd, 2011, 09:39 AM   #15
kmanxj5011
kmanxj5011's Avatar
I like the idea, I may steal that, my tank is still in stock location, but something like that should still work id think?
Old November 22nd, 2011, 10:15 AM   #16
Asher
Jack stand wheeler
Asher's Avatar
Yeah I've come close to removing it on a tree a few times. As far as the size of the cut I need to get the axle positioned and see what i can get for up travel and go from there.
Old November 22nd, 2011, 11:57 AM   #17
John D
John D's Avatar
Have you seen the T&T Project Low Wagon over on NAXJA? He did awesome work on his rear wheelwells getting bigger tires and smaller lift to work and it still looks like an XJ.
Old November 22nd, 2011, 09:18 PM   #18
Asher
Jack stand wheeler
Asher's Avatar
I like the T&T project lots of good ideas in his build. I like how he used the small OD round stock to retain the factory look on the rear wheel wells. I'm toying with the idea of using 1.625od tube from the rocker on up and around the wheel opening. Just have not decided how I want it to finish at the back by the bumper yet.
Old November 23rd, 2011, 10:58 AM   #19
John D
John D's Avatar
When I do my wheel openenings in the back I was thinking of doing what he did, but also I am considering larger tube to make into flares. I will probably use 1" pipe. It's cheap durable and I have a pipe bender already. I will also cover the quarter panel in 3/16 which will make it easier to weld together and I won't have to deal with filler.
Old December 23rd, 2011, 10:39 PM   #20
Asher
Jack stand wheeler
Asher's Avatar
Finished up the front bumper.
The tubes at the mounds and my less than gentle driving style ended up with my rockers getting a little dinged up.
So after breaking a few t40 torx bits and a can or two of PB blaster my doors relented and came off.
Started cutting out the rocker panel. I'll be using 6x2x.187 wall tube to replace them.
The amount of dirt in the rockers was impressive.
Got it trimed out start fitting in the tube over the weekend.
Page generated in 0.51653 seconds with 83 queries
