96 Powerstroke question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 18th, 2011, 04:46 PM   #1
LS6454
LS6454's Avatar
Default 96 Powerstroke question
I have a 96 F-250 with a turbo powerstroke . I have a problem with what i think might be the glow plugs. If i try to start it after it sits overnight it will not start. But if i plug the truck into 110v it will fire right up. I can drive it into town and turn it off and go inside a store or restaurant, come outside and it starts just fine. Leave it for any longer and it wont start again.
Any ideas what the problem might be ??
LS6454 is offline   Reply With Quote
Old November 18th, 2011, 04:51 PM   #2
kevinr839
kevinr839's Avatar
I would replace the glow plug solenoid/relay first. Right on top of the intake. Looks like a starter solenoid.
kevinr839 is offline   Reply With Quote
Old November 18th, 2011, 04:59 PM   #3
LS6454
LS6454's Avatar
Thanks, I will try that. Iam looking for inexpensive fixes first before i go hog wild and spend allot of money. Iam thinking it has to be something simple. The truck only has 95,000 miles on it.
Old November 18th, 2011, 05:17 PM   #4
blade262us
blade262us's Avatar
Default Powerstroke
A quick test for that is to take a big bolt 1/2 inch or bigger in diameter and put between the 2 big terminals of that solenoid and short them together tightly . Count to about 10 and start it if it fires right up its definately the relay is bad or not being energized . I say to use a bolt that big because there is alott of curent draw on that system and anything smaller may start to glow red in your hand branding you . This also is good to know if your in the middle of nowhere with limited test equipment .
blade262us is offline   Reply With Quote
Old November 18th, 2011, 06:10 PM   #5
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Make sure to hold bolt with pliers, also check the wiring that runs to the glow plugs. It can rub on valve covers.
Old November 19th, 2011, 04:56 PM   #6
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
simple volt meter will do the trick. I just replaced mine last month because it would sometimes not start. The meter showed it would cycle from 8-11 volts. Found a napa part that was $20 instead of OEM ford which is around $80. Works great now with no issues.
Old November 20th, 2011, 07:53 AM   #7
Fullsize4life
Kicking Cancers ASS
What is he napa part number?
Old November 21st, 2011, 06:47 AM   #8
Elvis13
accurate diesel sells one for $35 Made in Usa.
I think Napa's is GPR 109
Old November 29th, 2011, 10:39 AM   #9
orionn
orionn's Avatar
If you dont already know, the 50amp fuse will also blow and cause a no start.
Dont skimp on the glow plug relay when you replace it, its just not worth it. fix it once.
I dont know which one is on mine but its a huge 'ol thing, very heavy duty cycle.
Also, you should replace the glow plugs, they are due. Be sure to use only IH or FORD packaged glow plugs, the aftermarkets tend to swell and break off (Big $$ to fix).
orionn is offline   Reply With Quote
Page generated in 0.34201 seconds with 50 queries
