steering box fail.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 17th, 2011, 02:54 PM   #1
deathbypsi
Brian R.
deathbypsi's Avatar
Default steering box fail....
On my way home from work lastnite the steering box seal in my 94 F150 let go.
Is it worth tryin to just replace the seal? I have read it can be a major PITA and some people say ts easier to just replace the box. I have a low mileage box off a 88 Ranger I could swap in if doing the seal is not worth it.
Opinions?
Old November 17th, 2011, 02:58 PM   #2
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
$145 for the box. $7.00 for the seal. Not sure. How many miles are on the box that is leaking?
Old November 17th, 2011, 03:15 PM   #3
firecat
firecat's Avatar
my mechanic friends always say replace the box. the shaft may be wandering, new seal could get damaged during replacement, etc. mine leads badly, stop-leak products are not helping, very annoying. (95 jeep zj)
firecat is offline   Reply With Quote
Old November 17th, 2011, 03:17 PM   #4
FORD FLARESIDE
6'-1" 185lb 14YO Griffin
FORD FLARESIDE's Avatar
Replace the gear box..........................and buy a good pitman arm puller.
Old November 17th, 2011, 11:23 PM   #5
NewGuy
Let me know if you have any more gear boxes. I need one for my 94 explorer project I talked to you about lol. Mine leaks really bad!
NewGuy is offline   Reply With Quote
Old November 17th, 2011, 11:24 PM   #6
NewGuy
Oh if you need one we should stock it at my work. Just let me know and I'm sure I can get u a good price on it
Old November 18th, 2011, 08:53 AM   #7
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
FWIW I've changed seals in 3 fords, 2 of them were a breeze and worked great. The third was a major pita and leaks still leaks a little.
Old November 18th, 2011, 11:29 AM   #8
deathbypsi
Brian R.
deathbypsi's Avatar
MIne has 165k on it now so it might be better to just change it Im thinking.
Old November 18th, 2011, 12:37 PM   #9
osteologation
The 2 that I changed that were easy were because the pitman came right off, the last one I had no torch so I had to beat the hell out if it to get the arm off. I probably tweaked the opening. If your arm comes off easily I wouldn't hesitate to change the seal it's the easy part.
Page generated in 0.27784 seconds with 50 queries
