8.25 in a TJ?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 15th, 2011, 10:37 AM   #1
parkfan
parkfan's Avatar
Default 8.25 in a TJ??
Has anybody transplanted a 8.25 outta a ZJ into a TJ? I was wondering if where they're both coil sprung, if their bracketry is similiar enough? OR not?
parkfan is offline   Reply With Quote
Old November 15th, 2011, 10:47 AM   #2
firecat
firecat's Avatar
is there a zj that came with an 8.25? dana 35...
firecat is offline   Reply With Quote
Old November 15th, 2011, 10:48 AM   #3
GREASYHANDS
GREASYHANDS's Avatar
Could be a 44 also.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old November 15th, 2011, 10:52 AM   #4
ajmorell
The 8.25 never came in a ZJ
Originally Posted by GREASYHANDS View Post
Could be a 44 also.
The 44 also never came in ZJs, the 44a did but it is nowhere near the same as an iron 44. Regardless the brackets aren't identical. They are similar but some modification will be required.
Old November 15th, 2011, 11:08 AM   #5
GREASYHANDS
Good info
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old November 15th, 2011, 11:11 AM   #6
Complete Off Road
Complete Off Road's Avatar
this is true. And while there is a little (very little) aftermarket support for the aluminum housing D44A in ZJs, it is pretty much entirely different that a 'standard' D44 and is not a great candidate for a swap. "Standard' D44 lockers, ring & pinions, etc, do not work in a D44A (also referred to a D44HD by some aftermarket companies)
Complete Off Road is offline   Reply With Quote
Old November 15th, 2011, 11:40 AM   #7
ajmorell
Good info. There is enough aftermarket support to make the 44a pretty stout but there are two big limitations as far as I'm concerned:
-The obvious aluminum center section. It will eat bearings because it flexes more than a traditional iron center section. There is a company out there making a nice truss but I'm not going to mention their name since I have heard of a lot of problems from them lately. Regardless if you have a 44a, a truss is a good way to add a lot of strength and it will help eliminate the flex that eats bearings in these.
-There is very limited support for traction devices. Aussie was offering a locker for the 44a but last I knew they discontinued it. I though I saw that Yukon was making a grizzly locker for the 44a but I can't confirm that
Old November 15th, 2011, 07:21 PM   #8
parkfan
parkfan's Avatar
wow, ok. Thanks. Guess I'll keep looking for a 8.8. Just wish I could find one that I didn't have to send a whole day driving to go get
Old November 16th, 2011, 05:29 PM   #9
Bleay
sick of jackstand wheelin
Bleay's Avatar
Check http://www.car-part.com/ i will bet you can find one closer than you think.
Bleay is offline   Reply With Quote
Old April 8th, 2012, 09:55 AM   #10
butcyh cassidy
butcyh cassidy's Avatar
the dana 44a is not a bad axle. it does need some minor "adjustments" to strengthen it and thats just due to it being a solid axle. (aluminum mated to cold rolled steel axle tubes.) dodge used a independent rear version in the srt10 vipers and chevy threw that same irs rear end behind the new vetts. so I think from my personal experience the center is nothing to complain about...
butcyh cassidy is offline   Reply With Quote
Old April 9th, 2012, 01:28 AM   #11
go1lum
Just a thought but how close would an 8.25 out of a KJ be to bolting up? I think they are around an inch wider than the xj one though.
go1lum is offline   Reply With Quote
Old April 9th, 2012, 09:12 AM   #12
VAhasnoWAVES
Dirty South
VAhasnoWAVES's Avatar
bolting up to what? i dont think itll fit in anything other than a KJ without redoing the brackets.
the 8.25 is a solid axle, and can last on 35s. but for the amount of work to be done putting it into TJ or anything else with coils in the rear, it isnt really worth it IMO. a D44 or 9" would be a lot more worthwhile, as youll likely never replace it unless you go to tons. the cost is just too much, its not imply slapping on leaf spring perches like an XJ or YJ. but if your sure youll never go over 35s, you score a deal on an axle (locked, geared, etc)... id do it.
VAhasnoWAVES is online now   Reply With Quote
Old April 9th, 2012, 01:07 PM   #13
bdd1469
bdd
bdd1469's Avatar
Im a chevy guy,so this hurts.
The ford 8.8 is a much better choice then a 44,a8.25 or a 9" unless you are swapping front axle also.
The 8.8 is stronger then most,the bolt pattern is correct,huge aftermarket support.
The only potential problem is busting a c-clip axle,but the rotor will keep the wheel from falling out.I have not seen a 8.8 axle bust,except at the drag strip.
I would drive four hrs in a heartbeat to put in a superior axle,and not have to worry about it breaking.
If you have a lkq autoparts around you ,they only charge about $150 for a 8.8 complete minus brakes.
Old April 9th, 2012, 02:49 PM   #14
VAhasnoWAVES
Dirty South
i disagree with the idea that the 8.8 is a better option than a 9"
it lacks pinion support
and is C clip (though i dont see this as much of a downside)
non removable 3rd member
narrower width than stock
will the 8.8 last longer than most jeep front ends? yes. and id take it over a 44 rear. but its by no means "better" than the 9". a more fitting swap? sure. cheap 4.10 gears and disk break option? deffinantly. but why go through 5 different rear ends? throw a 9" in there and some wheel spacers/adapters on the front. the 9" will compliment almost anything you put up front.
i still say, know what width you want what tire size you want to run... and wait for a deal on an axle that fits the bill.
Old April 9th, 2012, 05:02 PM   #15
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
You clearly missed the most important part of that sentence.
*2007 Rubicon
*2006 Duramax
Old April 9th, 2012, 09:17 PM   #16
VAhasnoWAVES
Dirty South
at larger tire sizes... a little extra width is nice. to each, their own.
Page generated in 0.55946 seconds with 71 queries
