Project "What Were We Thinking" - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 14th, 2011, 08:37 PM   #1
branch92
Only in a jeep
branch92's Avatar
Default Project "What Were We Thinking"
Well 4bangler delivers again.. he hooked up snopro91mi with a 87 jeep cherokee with a 4.0 and no trans. it has been sitting for at least 3 years on his property untouched and was said to be sitting 4 years before it was driven to his property. so it has been sitting for roughly 7 years. 4bangler pulled the trans and sold that away so it was a perfect candidate for a ax15 swap seeing how it originally came with a BA10.
How it looked when it was pulled onto the trailer
4bangler hauled it to my house and tear down began
more pics and progress to come
branch92 is offline   Reply With Quote
Old November 14th, 2011, 09:14 PM   #2
branch92
Only in a jeep
branch92's Avatar
how it sits in the garage
we started by taking everything out of the interior and this is what we found
as you can see around 7 years of sitting in an open field has not be nice to this thing
As for where we are now... we have all the unibody repaired and are tracking down the last few parts for the trans swap. Floors will be going in soon and then a 6 inch lift
Old November 27th, 2011, 11:00 AM   #3
branch92
Only in a jeep
branch92's Avatar
well after lots of research and some modifing the trans and transfer case are in
then we tackled the front lift and the lower control arm bolts were a PITA but we got the lift in
then we did rear lift for this we built spring packs and added a 2 inch lift block. seeing how this thing has been sitting outside for the last 3 years we werent even going to try and pull the leaf spring bolts out
we changed all of the fluids hooked up the coil and ...... It started !!!!
lots more work to do yet
Old December 4th, 2011, 07:01 AM   #4
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
bbrancheau is offline   Reply With Quote
Old December 4th, 2011, 02:35 PM   #5
kmanxj5011
kmanxj5011's Avatar
Good luck with aluminum lift blocks. I had em come out back when o was a cheap ass. They'll actually compress and get smaller from pressure.
kmanxj5011 is offline   Reply With Quote
Old December 4th, 2011, 06:26 PM   #6
branch92
Only in a jeep
branch92's Avatar
Originally Posted by bbrancheau View Post
thanks for the arms
and we just got the driveshaft done should be moving under its own power tomorrow
Old December 5th, 2011, 09:41 PM   #7
branch92
Only in a jeep
branch92's Avatar
now moving on its own.. still have TONS of work to do but should get done alot faster now that this thing is alot easier to move around
Old December 17th, 2011, 11:37 PM   #8
branch92
Only in a jeep
branch92's Avatar
sitting next to mine. havent gotten much done in awhile but should pick back up after christmas
Old January 17th, 2012, 07:14 PM   #9
branch92
Only in a jeep
branch92's Avatar
well we managed to get nothing done on it in awhile but moved it to a warmer work place. planning to get back at it soon
Page generated in 0.44872 seconds with 50 queries
