F150 Exhaust Manifold - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 14th, 2011, 08:50 AM   #1
chevyk10
FORD / GM
chevyk10's Avatar
Default F150 Exhaust Manifold
Anyone have any tips for removing these 2 studs on the front of the manifold? Looks like they're rusted on there so bad they've completely bonded to that hook. 95 F150 5.8L.
chevyk10 is offline   Reply With Quote
Old November 14th, 2011, 10:23 PM   #2
Yota Bill
those are studs with an integral nut, so there is one hex nut, then the bracket slides on the stud, and then the outer nut. Cut the outer nut off and then thread the stud out. If you try to thread the outer one off, it will likely loosen the whole stud, twist and bend the bracket, and lock everything together
Old November 15th, 2011, 11:17 AM   #3
chevyk10
FORD / GM
chevyk10's Avatar
what would you reccomend using to cut the outer nut off? i can't seem to fit a saw or anything down there to cut it. I figured I could somehow cut that nut off, pull the bracket off, then weld a new nut to the end of the stud and try turning it out.
Old November 15th, 2011, 09:47 PM   #4
Yota Bill
right angle die grinder with a cut off wheel arbor. a little slower then a straight die grinder, but fits much easier
Page generated in 0.15804 seconds with 35 queries
