engine turns over very slow - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 11th, 2011, 11:32 PM   #1
tonkatruckon44s
tonkatruckon44s's Avatar
Default engine turns over very slow
engin tuns over very slow.... first off i tore down the engine and replaced the timing chain i made sure to top dead center the number 1 cylinder and line up the timing marks were lined up and then i put everything back together. i got the motor put back in the truck and hooked everything up it is a brand new battery and starter just bought today. my friend thinks it is the fact that we didnt ground the block to the frame or body but i think it is because we never reset the distributor.
tonkatruckon44s is offline   Reply With Quote
Old November 11th, 2011, 11:40 PM   #2
kevinr839
kevinr839's Avatar
Try to hook up the negative clamps of a set of jumper cables to the negative post of the battery and the starter bolt and see if it changes anything.
kevinr839 is offline   Reply With Quote
Old November 11th, 2011, 11:55 PM   #3
tonkatruckon44s
ill try that tomorrow but what exactly will that do make the starter ground
Old November 12th, 2011, 07:25 AM   #4
TanTahoe
TanTahoe's Avatar
The starter it's self does not have a negative wire to ground out to, it just grounds out on the starter housing thru the block. So the closer your ground is to the starter the better the connection. The jumper to the start bolt will help complete the circuit to verify it that is your problem or not.
TanTahoe is offline   Reply With Quote
Old November 12th, 2011, 08:16 AM   #5
1slo_camaro
LONG STORY SHORT, IM 23
1slo_camaro's Avatar
grounds, grounds, grounds, grounds, grounds, grounds.... MOST COMMON ISSUE FOR THIS!!!! make sure you have a VERY good ground from Battery> Frame, Battery>motor Motor>frame ( i prefer atleast 3 points... just my suggestion. make sure you have good grounds and if not all your going to do is fry your battery cables
1slo_camaro is offline   Reply With Quote
Old November 12th, 2011, 08:58 AM   #6
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I prefer this setup:
Battery (-) directly bolted to engine block, then an additional grounding cable from the block to the frame.
Battery (+) to an insulated junction box that feeds the stater and the rest of the vehicle.
@clarkstoncracker
Old November 12th, 2011, 09:44 AM   #7
kevinr839
kevinr839's Avatar
[QUOTE=TanTahoe;2845694]The starter it's self does not have a negative wire to ground out to, it just grounds out on the starter housing thru the block. So the closer your ground is to the starter the better the connection. The jumper to the start bolt will help complete the circuit to verify it that is your problem or not.[/QUOTE
Exactly what he said. It is just a quick check to help isolate if that is your problem. You could also use the other 2 clamps to go from motor to frame or body just to complete the circuit more. Grounds are very critical to completing the "circuit" and making everything work good.
Old November 12th, 2011, 11:09 AM   #8
tonkatruckon44s
yeah i have a friend helping me swap the motors and he wont listen to me on anything when we were putting the motor back in i wanted to hook the grounds on the back of the engine block back up but he said no i never use grounds i thought it was weird so ill try hooking up all the grounds and if that doesnt work ill try grounding the starter.
Old November 12th, 2011, 11:16 AM   #9
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
tell your friend he is an idiot.
Old November 13th, 2011, 10:42 AM   #10
tonkatruckon44s
yeah pretty much he just had a cherry picker and i dont
Old November 13th, 2011, 12:05 PM   #11
bdd1469
bdd
bdd1469's Avatar
Your freind doesn't seem too smart,see if you can get him to hold on to the positive battery cable while you crank it over.If your freind screams,and jumps away from the truck,with burnt fingers,you have a bad ground.
Old November 13th, 2011, 12:15 PM   #12
buttercr125
I work out
buttercr125's Avatar
X2 on this one. I sometimes even take it a step farther and run the Battery (-) directly to the engine block, then a separate one from the battery directly to the frame and another one from the engine block to the frame. Might sound like overkill but I have never had a ground issue on anything I built.
Old November 15th, 2011, 12:34 PM   #13
tonkatruckon44s
okay finally got it to start literally what i did is i went out to it the other night turned on the lights to make sure the batter wasnt drained to much while i tried to start it. then i shut the lights off and tried it one last time didnt hook anymore grounds or mess with the dizzy and it fired right up, it turned right over i have no idea what it was but it still turns over every time. im going to investigate it a little bit and see whats going on. btw does anyone here have any vaccuum diagrams for that year tbi motor.
Old November 15th, 2011, 12:45 PM   #14
Flexin' XJ
Flexin' XJ's Avatar
Crank speed is not dependent on the distributor. So you could have the distributor out and it should still crank fine but not start. Just an FYI.
Flexin' XJ is offline   Reply With Quote
Old November 15th, 2011, 12:47 PM   #15
tonkatruckon44s
i already got it started
Old November 15th, 2011, 01:46 PM   #16
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
what year TBI?
@clarkstoncracker
Old November 17th, 2011, 01:37 AM   #17
tonkatruckon44s
1989 i think its fuel pump gone bad
Old November 17th, 2011, 10:43 AM   #18
Flexin' XJ
Flexin' XJ's Avatar
I saw that. I was just giving you information for the future.
Old November 17th, 2011, 12:20 PM   #19
I suck cocks. Lots of them.
locally famous
next time borrow it
Old November 17th, 2011, 11:17 PM   #20
tonkatruckon44s
definately the fuel pump not and i have to replace sending unit and tank because they both are rotted found why pump went bad because the inside of the tank was so rusty the fuel strainer in the tank was clogged up so bad it was black burnt out the pump damn if it isnt one thing its another
Page generated in 0.34486 seconds with 83 queries
