late 99 f350 engine inconstant idle, loping, barley running - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 8th, 2011, 09:07 AM   #1
219xj
219xj's Avatar
Default late 99 f350 engine inconstant idle, loping, barley running
some background on what ive done in the past few weeks.
i had a bad oil pan and it was leaking so i decided it was time to replace it. so i pulled the engine and replaced it. i had a leaking ebpv and i decided to delete it while i had the turbo off. while the engine was out of the truck and the injectors were right there i thought now might be a good time to look at them. so i took them out and put all new o rings on them and installed them again. inspected glow plug/ injector harness and it was fine with no cracks or broken wires. put the engine in it and after a little cranking she fired up and was running great. i took her out and drove about 80 miles. only issue was i kept blowing off my ds intercooler pipe on the top boot. but other than that it was running great noticeably more power, and throttle response. i was extremely happy with everything and how well it was running.
now for my problem
i was driving it to a buddies house and i noticed when i got there it was idling kinda weird. it was very minimal but you could hear a miss or a funny idle.. when i tapped on the throttle it took longer to return to the stock idle. it would stop around 1200 and sit there for about 10 seconds before returning to normal idle.. also its still making the funny missing noise. well i shut it off and come back about 20 min later to leave and she fires up but still is idling weird. so i start to drive home and my power seemed much less. when i took it out of gear to coast it would have a crazy lope. like almost die and then it would peak at about 1000 rpm. i put it back in gear and gave it some gas and it was running fine( or you couldnt notice a miss just a slight loss of power) so i seem like i just barley get it home and shut it off. i later start it up to move it and it went to high idle.. my high idle switch isnt on just the truck is doing this. it would high idle then to a huge lope idle for about 5 seconds then go to just barley running back to high idle then just keep on being inconstant. there was no pattern to what it was doing. it sounds like a fuel problem to me.. the fuel filter was new about 2 months ago. and i inspected it and its still white no sign of dirt or debris. could i have stiction? im unaware of the injectors age. my truck had 280,000 and was running just fine before i pulled the engine. im just hoping to get some solid answers. thanks in advance
219xj is offline   Reply With Quote
Old November 8th, 2011, 10:04 AM   #2
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I would start by putting a fuel pressure gauge on it. Could be bad fuel. I filled up at Mejiers once and it ran funny. Bad CPS? could still have air in the lines from pulling injectors. I know people say it takes a while to get it out.
Old November 8th, 2011, 11:13 AM   #3
219xj
219xj's Avatar
ill try that
Page generated in 0.22297 seconds with 32 queries
