Ranger on da cheap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 7th, 2011, 05:26 PM   #1
98-S10-lifted
98-S10-lifted's Avatar
Default Ranger on da cheap
I wanted something that wasn't the greatest so I could have some fun offroad that I didn't care too much for.
Starts as:
1990 Ranger STX, Auto, 4.0L, push-button T-case, said to be 81,000 miles looks to be about right.
Wanted it to be cheap, don't want to sink too much into it.
Parts:
- 2" spacers from a previous project
- AutoZone "chevy lowering shackles) ~2" of lift
- Had to get new hangers
- Body lift
- Bolts/ nuts/ washers
- Manual 1354 T-case junkyard
May do solid axles over the summer find out when I get there.
98-S10-lifted is offline   Reply With Quote
Old November 7th, 2011, 05:28 PM   #2
98-S10-lifted
Back Body lift and shackles done
Old November 7th, 2011, 06:36 PM   #3
ddeadserious
ddeadserious's Avatar
Looks nice.
I don't believe you'll keep it long enough to complete your plans and wheel it.
ddeadserious is offline   Reply With Quote
Old November 7th, 2011, 09:15 PM   #4
98-S10-lifted
That is very well possible. But I'm almost done putting it together.
Old November 12th, 2011, 05:21 PM   #5
98-S10-lifted
I got the lift spacers on between yesterday and today, Then I got part of the way started on the body lift for the front. It is sitting on the body pucks, just have to cut off the broken bolt pieces and get to work.
I have a ton of re-aligning to do on the body and a bunch of welding to do to fix some rusted out body mounts on the frame end of the deal. Managed to tear a radiator hose so I have that to add to the list.
No pics til I get it bolted back down.
Old November 13th, 2011, 05:05 PM   #6
98-S10-lifted
Just have a few things to finish up to complete the whole body lift process. Extend the steering shaft, move the bumper and check it all over.
Only things I need to do are, change trans fluid, put the 1354 T-case on, and deal with the tires; possible do some cutting to the body.
Old January 6th, 2012, 03:50 PM   #7
98-S10-lifted
Project undo.
Making it back down to stock, rear is all done. Body lift and shackles taken off and put a bumper on that I got from the junkyard.
Tomorrow I am putting in the Transfer case and at least taking off the coil spacers hopefully the body lift too.
Old January 6th, 2012, 04:01 PM   #8
xjmichigan
xjmichigan's Avatar
Why
Old January 6th, 2012, 04:20 PM   #9
98-S10-lifted
Just going to drive it around stock and work on my blazer a little bit. I would rather do something to my blazer than this.
I can't get what I want for it really cheap and don't want to settle for less so if I am going to drop money into something I would rather it be into something I comeplety like. The ranger was something I didn't know if I wanted to continue with.
Page generated in 0.23124 seconds with 50 queries
