Pinion seal question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 6th, 2011, 12:58 PM   #1
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Default Pinion seal question
2004 F-150 4x4
Sterling 9.75
I am going to replace the pinion seal in the rear axle. Does the pinion nut have a torque spec to maintain proper bearing pre-load?
Old November 7th, 2011, 08:33 AM   #2
DUNE JUMP
DUNE JUMP's Avatar
Originally Posted by HVYRTFT View Post
2004 F-150 4x4
Sterling 9.75
You're going to want to do a pinion torque to rotate measurement before you remove the pinion nut, and match that when you re-assemble. The axle is set up new to a specified torque to rotate value, but after the bearings run for a few thousand miles, the TTR will drop. Many a bearing set has been destroyed after the nut is torqued to achieve a "new" range TTR on a used set of pinion bearings.
Old November 7th, 2011, 10:40 AM   #3
GREASYHANDS
GREASYHANDS's Avatar
I have good luck marking the pinion nut and the pinion with a center punch. Chech the rotational force before and after using your marks as a guide .
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Page generated in 0.21568 seconds with 32 queries
