1972 jeep cj 5 restored 4200 obo - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 5th, 2011, 03:27 PM   #1
walkingbigtree
Default 1972 jeep cj 5 restored 4200 obo
For sale is a 1972 jeep cj 5. All original steel tub, with frame off restoration. Frame was wheeled and blasted to bare metal, and then sprayed with industrial enamel. All new brake lines and fuel lines installed. Axles were wire wheeled down, diffs drained, and sprayed. Axles were swapped to give a spring over lift (SOA). Roughly 6 inch lift. Rear drive shaft has been lengthened, stock front drive shaft. All new u joints, all new shocks. New brakes. Front axle has been converted to disc brake. All frame hardware replaced with grade 8 bolts. Transmission is original 4 speed, transfrer case is dana 20. Both taken out, wire wheeled and sprayed. Motor was pulled and power washed. Original cj 258 straight six. Tranny has good clutch. Motor runs great, no smoke, no leaks. All fluids were drained out and changed. All lites work, foot switch for brights, all bulbs have been changed out. Tub is all steel, along with fenders and original steel hood. Fresh paint job, light kahki with black accents. Interior has original upholstery, in great condition. Dash is complete except radio. Has tilt steering column, power steering and new drop pitmann arm. New windshield glass. Comes with soft top and soft doors. Currently on 33" power cats. Runs and drives great. $4200 OBO Call or text 906 281 4789 or revoght@mtu.edu
walkingbigtree is offline   Reply With Quote
Page generated in 0.14547 seconds with 26 queries
