Aftermarket NP231C Shifter - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 4th, 2011, 05:58 PM   #1
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Default Aftermarket NP231C Shifter
I found an aftermarket NP231J shifter by Novak, but it says it is not compatible with the 231C due to a different bolt pattern. I can't see exactly where it bolts on in the pictures to figure out if I can modify it.
I HATE the factory 700r4/231C shifter and would like to replace it. Has anyone found or used an aftermarket shifter for the 231C?
Old November 6th, 2011, 05:31 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
It bolts to the studs on the front of the transfer case (that you use to bolt the t/c to the transmission).
I haven't used one for the 231C, but I've used one with an adapter for the 700R4 to NP231J and it required just the slightest modification.
Old November 6th, 2011, 09:29 PM   #3
jeepfreak81
81 inches of fun
Good to know. If Adam doesn't have luck modifying mine I will try that route.
Old September 16th, 2013, 10:20 AM   #4
Green Jeep
97 TJ GM 4.3 700R4
I am in the middle of a 1997 TJ build. I just got the 4.3 motor 700R4 and NP231C Tcase installed. I ordered the Novak Tcase shift cable Friday. Will be here Thursday of this week. Once I get it installed I will post pics. I know I will have to modify the bracket at the Tcase.
Green Jeep is offline   Reply With Quote
Old September 23rd, 2013, 12:49 PM   #5
Green Jeep
97 TJ GM 4.3 700R4
I installed the Novak transfercase shift cable onto my NP231C in my 97TJ. See pics.
Very easy modification. All I had to do is bend the top peice of the bracket and weld a extention to so it would bolt to the factory GM bracket.
ID:	110676   Click image for larger version
ID:	110677   Click image for larger version
ID:	110678   Click image for larger version
ID:	110679   Click image for larger version
Page generated in 0.17168 seconds with 39 queries
