power steering - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 4th, 2011, 01:31 AM   #1
mudzuk21
mudzuk21's Avatar
Default power steering
what is the cheapest way to put power steering on my samurai?
mudzuk21 is offline   Reply With Quote
Old November 4th, 2011, 01:42 AM   #2
deerebowtie
Unchained
deerebowtie's Avatar
junkyard a power steering box from an older ford pickup, modify your frame to make it fit. junkyard a power steering pump and make a bracket to mount it up, then get hoses and a longer belt? pretty easy in concept.
http://zukiworld.com/forum/build-dia...teering-setup/
Old November 6th, 2011, 02:22 PM   #3
A4X4SPIT
A4X4SPIT's Avatar
most people use a tracker or side kick power steering set up its not a direct bolt on but works good trail tuff,sky manufacturing & most of the suzuki vendors have kits that make it a bolt on set up . Ive done it with & without the kit Its easy with the kit and not that bad with out it if you got some fab skills
A4X4SPIT is offline   Reply With Quote
Old December 3rd, 2011, 09:16 AM   #4
JACK48461
HEAVY D
Go with the tracker set up i just bought a complete set up from someone for $100 used. I've looked everywhere i could and if you had to buy new lowrangeoffroad.com has a complete kit new for I believe $400.00 but the best would for sure be to hit a junk yard and make sure you grab everything off the sidekick/tracker hoses reservoir and all.
JACK48461 is offline   Reply With Quote
Page generated in 0.17263 seconds with 35 queries
