Locker or limited slip - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 13th, 2005, 11:59 AM   #1
noodles
give 'er sh*t ay?
noodles's Avatar
Default Locker or limited slip
Your opinion on a locker and a limited slip. If you drive on the road alot, but yet go to silver lake, mounds ( hopefully) and maybe th badlands. I go wheeling around school, and was just wondering what would be the best. I also tow with the truck. Just wondering what you guys woudl chose and why. Thanks
Old December 13th, 2005, 03:54 PM   #2
Jeeptj1999
Jeeptj1999's Avatar
When I did the 35 spline 9" I was having trouble deciding on a spool over a locker, I opted for a Detroit and was very happy, I had previously had a limited slip in my other jeep. The 35 spline detroit rarely unlocks and when it does you think you broke something, but it's better in the snow then what people said it would be. Good luck.
Jeeptj1999 is offline   Reply With Quote
Old December 13th, 2005, 04:03 PM   #3
scorpio_vette
scorpio_vette's Avatar
Send a message via MSN to scorpio_vette Send a message via Yahoo to scorpio_vette
how about a limited slip locker???
i probably shouldn't post this since i don't remember the company, but just the other day i was fliping through a magazine and found one that when dis-engaged acts like a limited slip and when engaged is a full locker.
maybe somebody else can pitch in and help me with a brand name.
scorpio_vette is offline   Reply With Quote
Old December 13th, 2005, 07:23 PM   #4
318/392
318/392's Avatar
Send a message via AIM to 318/392
http://www.detroitlocker.com/DE.htm
go look at this....."The Detroit Electrac functions as a heavy-duty limited slip differential and a driver-activated fully locked performance differential."
318/392 is offline   Reply With Quote
Old December 13th, 2005, 08:02 PM   #5
scorpio_vette
i knew i saw that somewhere.
Old December 13th, 2005, 09:03 PM   #6
Tonka
Tonka's Avatar
my vote is for a selectable locker
Old December 13th, 2005, 10:08 PM   #7
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Auburn Gear Ect-ed is the same thing...LSD in normal more, and spooled when engaged.
Old December 13th, 2005, 10:32 PM   #8
Chop
Mischievous Badger
Chop's Avatar
Detroit locker all the way
Old December 13th, 2005, 11:08 PM   #9
noodles
give 'er sh*t ay?
noodles's Avatar
I would like to go with a selectable locker but they are reallly fricken expensive. Unless anyone knows of a cheep one for a cry 9.25
Old December 14th, 2005, 01:55 AM   #10
Mclovin
"The Situation"
Mclovin's Avatar
Ryan i told you to come down to my house for a weekend and we'll get yer axle locked in no time
Old December 14th, 2005, 01:56 AM   #11
noodles
give 'er sh*t ay?
noodles's Avatar
shut up cronk, if i wanted that type of locker ive got the ablity to do it at my house..
Old December 14th, 2005, 02:10 AM   #12
Mclovin
"The Situation"
Mclovin's Avatar
or in your dorm room right ??
Old December 14th, 2005, 02:11 AM   #13
noodles
give 'er sh*t ay?
noodles's Avatar
indeed
Old December 14th, 2005, 03:15 AM   #14
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Welded rear is the only way I would go anymore. Trail or street. Predictable and cheap.
JcrOffroad
Zoom Zoom!
Old December 14th, 2005, 08:51 AM   #15
Bones
Bones's Avatar
vote for weld. Unless you have a heavy rig, a Detroit will stay engaged around most corners anyway. The Lincoln locker will always be locked. you don't have to think about it locking up 1/2 way through a snowy corner when you wouldn't expect it.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 14th, 2005, 10:09 AM   #16
cornfed
I have an avatar. Yippee.
cornfed's Avatar
  • drive on the road a alot
  • Silver Lake
  • Mounds "hopefully"= rarely
  • "maybe the Badlands"= probably not with this vehicle
  • Wheelin' around school= MI two trackin'
  • Towing
Limited slip.
Old December 14th, 2005, 10:40 AM   #17
Yeah, as much as I hate to say it, a limited slip sounds like the best option.
Although, with the cost of buying one and then installing it, you might really see if you can step up to a selectable locker or something.
I kno wthat even the factory trac-loc in my TJ did better than a similar open diff'd vehicle in the snow. Likewise the trac-loc in my old Ram worked pretty well in the Dana 60.
But lockers are far above and beyond a LSD..
They are right, a lcoker isn't going to be all that un-locked around corners in something like a Jeep. And its going to slide around on snow and ice just as much.
Having driven a YJ before in the snow with a lock rite and 31x10.5 BFG ATs, it wasn't that bad. Having a tire thats good in the snow helps a lot. But you have to understand that it will change the characteristics a lot.
Really, its your call. A limited slip will help a bit off road, and be a little more slidey on-road. A locker or welded rear will help a ton off road and be a god bit more slidey on road.
Lockers/spool will defiantely wear the tires more.
Old December 14th, 2005, 10:51 AM   #18
noodles
give 'er sh*t ay?
noodles's Avatar
I would weld but I am not to keen on that, for some reasion i just dont like it unless its truly off road, ya know? Plus I have heard storys about the welds failing then destroying the diff.I am thinking about geting a lock right, for thoes who have it, is there a lot of tire wear?? or is this going to be something i am going to have to live with when i get a locker?
Again thanks for the input guys.
Old December 14th, 2005, 11:01 AM   #19
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
x100000000000
welding = teh whip.
that way when it breaks the only person you have to blame is your dumbass self.
the only way the welds are going to fail and destroy the diff is if YOU don't know how to weld....
I doubt your going to apply 10,000 pounds per square inch of force to your diff.. if you do, you should prolly upgrade axles while your at it..
Old December 14th, 2005, 11:41 AM   #20
Mclovin
"The Situation"
Mclovin's Avatar
I say the ECTD or w/e it was... that sounds like the bomb !
Page generated in 0.36699 seconds with 83 queries
