BUilding trailer axles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 3rd, 2011, 05:35 PM   #1
boggin-machine
boggin-machine's Avatar
Default BUilding trailer axles
Since I'm having a hell of a time finding trailer axles in the right width. I found a good set but are to narrow to clear the bed on my car hauler. Im thinking about just ordered the steel to cut to length that I need. My otters are good just the actual axle tube got bent. Am I missing something kn why I cannt do this? Just weld the new backing plates on?
Old November 4th, 2011, 09:18 PM   #2
gofastbobby
The guy Dale doesn't know
gofastbobby's Avatar
I have seen it done in the past. my neighbor whos a welder by trade did a set for me on an old car haluer of mine. he basically bought a thicker, larger piece of tube steel to slip fit the od of the axle, ran a fair amount of overlap and welded. I never had an issue with it.
Originally Posted by FlatFender View Post
America! Fuck yeah!
gofastbobby is offline   Reply With Quote
Old November 4th, 2011, 09:38 PM   #3
tw1st3d5
tw1st3d5's Avatar
I thought the axle tubes on car trailers came with a bend from the factory most of the time?
Old November 4th, 2011, 09:58 PM   #4
deerebowtie
Unchained
deerebowtie's Avatar
chop cut re-weld. if you can find a long straight piece of angle iron it would help to make sure they stay kinda true to help deter uneven tire wear.
Old November 4th, 2011, 10:01 PM   #5
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
More of a slight arc.
Old November 10th, 2011, 12:42 PM   #6
rideraa
rideraa's Avatar
"Camber" for sure. String a couple to get an idea on the amount.
It is also common to see the top side of tube frame main rails welded with a zig zag pattern. This shrinks the steel and creates camber. On "I" beam frames it can also be a straight weld along top web and flange fillet.
I mention this as possible way camber a tube or "I" beam. It is quite on common trailer frames.
You may want to decide for yourself what this practice does for the structural integrity.
rideraa is offline   Reply With Quote
Page generated in 0.30407 seconds with 41 queries
