Slo-Mo Rebuild - Page 9 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 12th, 2013, 04:06 PM   #161
jbsjunk
Little Member
jbsjunk's Avatar
That shines up nice.
Old April 12th, 2013, 04:19 PM   #162
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Nice work!
RDK_YJ88 is online now   Reply With Quote
Old April 12th, 2013, 04:50 PM   #163
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
I like it! Nice work.
*2007 Rubicon
*2006 Duramax
Old April 12th, 2013, 11:50 PM   #164
VAhasnoWAVES
Dirty South
VAhasnoWAVES's Avatar
Originally Posted by John D View Post
[/URL]
wow. turned out sharp. and i like the changes to your rear bumper a lot.
ill keep watching eagerly for the LED wiring. post where you got yours? most of mine need to be replaced.
VAhasnoWAVES is offline   Reply With Quote
Old April 13th, 2013, 03:58 AM   #165
John D
John D's Avatar
The single stage uerothane has held up very well. Last fall it was three years since I painted it.
Originally Posted by RDK_YJ88 View Post
Nice work!
Thanks guys.
Old April 13th, 2013, 07:14 AM   #166
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Front bumper is finally done (mostly), I still need to figure out my suck down winch. It pulls the front down to the bumps stops easily, but as soon as I take the power off it releases. I was putting power directly to the winch for testing. Do I need to have the winch solenoid hooked up to make it stay engaged?
As far as the suck down winch, do you have the rope wound backwards? i think the clutch might only work in one direction so if the rope is wound wrong direction the clutch might not work.
Why not use the front winch for both instead of haulin around the extra wieght of two winches?
sbcrichie is offline   Reply With Quote
Old April 13th, 2013, 08:34 AM   #167
John D
John D's Avatar
Good point about the winch, I bet that's the issue. I will check it out, I had it working in a different application so I know it's a good one.
As far as using the recovery winch, it's too far forward to be effective. When the ATV winch wasn't working I did try it and confirmed this. Besides the ATV winch only weighs about 10# or so. Here's a profile to show why the recovery winch won't work.
Old April 13th, 2013, 08:36 AM   #168
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
For a minute I though you welded the corners on, but looks like you just painted over the bolts? Blends really well Will be nice not to smash out tail lights anymore
Old April 13th, 2013, 09:43 AM   #169
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
i was thinking you could spool cable off of back of winch and maybe have a roller back there so the cable pulled straight up off the axle. you can get rid of the hook on the cable and use a clevis so you can easily put cable through the fairlead if you need it for recovery.
Old April 13th, 2013, 09:46 AM   #170
Sassy Beetle
rmcleods better half
Sassy Beetle's Avatar
Nice job
Sassy Beetle is offline   Reply With Quote
Old April 13th, 2013, 02:27 PM   #171
John D
John D's Avatar
Yep, stuck all the bolts in a piece of cardboard and blew paint on them when I was painting everything else.
Oh, I get it. I'm a bit slow sometimes
I actually already have an ATV fairlead back there I was planning to use with the little winch. I will try your idea, bet it works just fine.
Originally Posted by Sassy Beetle View Post
Nice job
Thanks
Old April 14th, 2013, 12:56 PM   #172
RossDickman
RossDickman's Avatar
Looks great! Looks like you did a lot of work to it and did it very well.
Now.... I gotta get to the barn and put together some axles
RossDickman is offline   Reply With Quote
Old November 16th, 2013, 10:36 AM   #173
John D
John D's Avatar
Well, this year did not go as planned. Work has been killing me with 70-80 hour weeks pretty regularly. I am grateful for the extra, but sheez. Didn't do any work to the Jeep and I never even got to take it out. Maybe put 200 road miles on it, it was a bummer. Anyway it's back in my shop and hoping to get some stuff done. Oh, and I put in a pool this summer. And I thought a Jeep was a money pit, ha!
Old November 16th, 2013, 10:52 AM   #174
firehawk
Live Action!
firehawk's Avatar
That is a nice looking backyard, wish I could have given you my pool, I'm over it.
Old November 17th, 2013, 02:52 PM   #175
John D
John D's Avatar
Lol. I'm hoping I get a good number of years out of the pool before I get sick of it. It's like being on vacation in that backyard, so lucky to have it.
My wife got me a B&M Hammer shifter for my birthday this year... That was in May. I finally got around to installing it this weekend. I should have done a real shifter a long time ago, it's so nice.
Before
After
Old November 29th, 2013, 02:32 PM   #176
John D
John D's Avatar
Finally got a day back in the shop and the gas tank fell out! LOL
Built up a frame to hold it up using 2" and 1 1/4" pipe I had laying around.
The plan is to cover the frame with 3/16".
I still need to decide how to secure it but it's coming along.
I started laying out my rear frame stiffeners today too. I think I will end up building a set like I did for the front where it wraps around the underside of the frame using 3/16".
Old November 29th, 2013, 02:39 PM   #177
Why YJ?
Don't be a wuss... HIT IT
Why YJ?'s Avatar
Nice, just started a LS XJ build as well. Saw some posts from you on other forums. I never knew you lived in MI.
2005 LJ comp cut, 1 tons, etc...
Paul
www.teamhodges.com
Why YJ? is offline   Reply With Quote
Old November 29th, 2013, 06:35 PM   #178
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Nice work, John (yet again).
Old November 30th, 2013, 07:19 PM   #179
John D
John D's Avatar
You will be happy when it's done, especially if you get to the dunes.
Thanks Craig
Old November 30th, 2013, 08:53 PM   #180
jbsjunk
Little Member
jbsjunk's Avatar
Wish I went with an LS instead of a small block, but I had the engine already. Maybe in it's next incarnation.
Page generated in 0.44494 seconds with 83 queries
