Slo-Mo Rebuild - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 1st, 2012, 06:07 PM   #121
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
I look forward to seeing the bumper.
Old December 27th, 2012, 08:30 PM   #122
John D
John D's Avatar
Finished up the frame sleeve for the driver's side (no pic, it's basically the same as the p-side). I wanted to fix two things with the D-side. (1) I had some damage to the frame where the steering box mounted due to an accident before I bought it and typical XJ cracks/failure in this area. (2) When I installed my D44 front I moved the location forward 2" and the pitman arm/track bar were very close as well as my 5.3L PS pump pulley was about 2mm from the steering box. So I wanted to relocate my steering box down and forward.
Banged it back into shape and fixed some of the damage.
Plated and redrilled for new location.
Steering box mounted down a little and forward.
Old December 27th, 2012, 08:37 PM   #123
John D
John D's Avatar
Craig ( 1x1_Speed_Craig ) hooked me up with a spare steering shaft to go with the relocated box - thanks Craig!
This is what I came up with, I think it will work pretty well. Now I can get to work n the bumper.
Old December 28th, 2012, 02:30 PM   #124
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
So what are you thinking for the bumper?
Old December 28th, 2012, 08:52 PM   #125
John D
John D's Avatar
I ran out of gas for the my welder so I will finish up and upload some pics tomorrow. I did my d-rings similar to yours but with a bit more movement allowed front to back.
My basic ideas were to keep the bumper low profile while putting my winch as low as possible. The previous bumper had super good clearance but the winch blocked most of my grill. It was most noticeable on the dunes when temps would climb and have a hard time coming down. I dropped it almost 6" with this design.
I also wanted to mount an ATV winch under the radiator to use as a suck down. Although its not quite finished I am pretty happy with what it's turned out to be.
Old December 28th, 2012, 10:53 PM   #126
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
I'm kind of excited to see what you come up with.
Old December 29th, 2012, 10:42 AM   #127
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
x2
*2007 Rubicon
*2006 Duramax
*2010 TDI
*2005 CRD
Old December 29th, 2012, 12:35 PM   #128
John D
John D's Avatar
Originally Posted by OnlyInMyXJ22 View Post
x2
Hope I can pull it off, that's a lot of pressure! I did have a little Jeep ADD this morning when I went to a friend's shop to use his plasma cutter. He made this computer controlled cutting table and the next thing I know we were putting in my rear frame measurements and cutting out my rear stiffies. Time to re-focus...
Action video
http://s960.beta.photobucket.com/use...06D65.mp4.html
Old December 29th, 2012, 05:13 PM   #129
John D
John D's Avatar
I still have to figure out what I want to finish it, but I have some ideas. I have some heavy wall poop pipe left over from when I did my first bumper 8 years ago. It held up really well to abuse, so I will be using it again.
Suck down winch tucked away under the radiator.
Recovery winch plate and bottom of the approach.
D-ring mounts like this on both sides, stole the idea from RDK
Instead of buying a d-ring mount I welded another piece of 3/16" plate to the outside and a piece of 1/4" angle tied into the frame horn. It's a total of 5/8" thick where the d-ring hole is.
Here's where it sits now until Monday. Most of my grill is open to airflow again so I'm happy.
Old December 29th, 2012, 06:59 PM   #130
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Looks good
Old December 29th, 2012, 07:06 PM   #131
RossDickman
RossDickman's Avatar
That bumper is looking nice and tight! Love all the funtions its doing at once!
RossDickman is offline   Reply With Quote
Old December 30th, 2012, 12:54 AM   #132
OnlyInMyXJ22
No Money = No Fun
Looks good
x2
I like it!
*2007 Rubicon
*2006 Duramax
*2010 TDI
*2005 CRD
Old December 30th, 2012, 02:00 AM   #133
snboarder113
snboarder113's Avatar
what is the smaller concealed winch for?
snboarder113 is offline   Reply With Quote
Old December 30th, 2012, 06:01 AM   #134
John D
John D's Avatar
Thanks guys.
As soon as I get it hooked up I will post pics of it working, but basically it hooks to the front axle to pull the front of the Jeep down on a steep climb.
Old December 31st, 2012, 12:17 PM   #135
John D
John D's Avatar
A little progress on the bumper, I'm digging it so far, what do you think?
Probably spent more time than anyone in history on my fairlead mount, but it came out nice. It's not easy to see, but there are a couple angles to bring it around the front and smooth it out.
Not quite done with the poop pipe, but its probably going to look something like this.
Old December 31st, 2012, 12:32 PM   #136
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Looks good. Are you putting plate in front of the tube, next to the fairlead?
Old December 31st, 2012, 12:37 PM   #137
John D
John D's Avatar
Yes, planning to fill that little strip, then put a top on the whole thing too.
Old January 1st, 2013, 01:11 PM   #138
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Should look good when it's all finished up!
Old January 5th, 2013, 02:44 PM   #139
John D
John D's Avatar
Mostly finished the bumper. I am very happy with the way it turned out. Low profile, tight and maintained a good approach while opening airflow to the radiator.
I'm going to cap the top like this. The hole is to access my suck down winch.
Old January 5th, 2013, 03:36 PM   #140
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Looks good! Can't wait to see it painted up.
Page generated in 0.38521 seconds with 83 queries
