1995 Isuzu Rodeo Lifted - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 26th, 2006, 11:32 AM   #1
Grumpy1
Grumpy1's Avatar
Default 1995 Isuzu Rodeo Lifted
1995 Isuzu Rodeo.
The good. It runs and drives. Rear is lifted with aals and shackles. Front has cranked torsion bars ( Not cranked anywhere near the max ) 3 inch body lift. Ran 33X10.50 swampers with no rubbing on road and only the slightest off at full compression. Currently has 235/85/16 pep boys mudders. Has trailmaster invader shocks all the way around. Disc brakes all the way around with a Dana 44 out back with Posi. Has a K&N filter. Has AC and an Automatic trans, power windows and mirrors. 16X7 Alloy rims. Truck has 112K miles. Currently being used as a DD
The bad. The trans shifter has been modified when the body lift was put on. It now uses a B&M 5 ft shifter cable. This cable needs replacing (about 40 bucks at summit ) Small drive line shudder. Pretty much done that since I put the add a leaves in 6 years ago. Shim it if it bothers you. Needs an exhaust Y pipe ( found it online for about 100 bucks ) Not sure about the rest of the exhaust but I would bet all will need replacing soon. My kid my kid rigged up the y pipe hole but its still loud. The hoods got a lot of small dents from his asshole friends sitting and playing on it. One rust hole on the rear about the size of a silver dollar the rest of the body has some rust but nothing bad. No stereo kids taking his out. It has some other small shit wrong but mostly like loose or missing trim on the inside. The rear Anti lock does not work since the tires exceeded 10% larger then the stockers. Never bothered me. The front tires need replacing. AC need recharging.
I bought this truck brand new and did all the work myself. Gave it to my kid a year ago who is an idiot and showed this truck no love so I'm taking it back. I always wanted to cut the roof and cage it. With a solid front axle it would be a bitchin wheeler. Had it at the mounds many times. With 33's it got about 12 mpg around town about 15 on the hw.
Price is 1600.00 I will consider trades but really need nothing other then some work on my jeep that I cannot do.
I'll post a pic later this afternoon.
ID:	3054   Click image for larger version
Grumpy1 is offline   Reply With Quote
Old September 26th, 2006, 07:05 PM   #2
scottie
Eye candy
scottie's Avatar
maybe if it was a Passport.......
Old September 26th, 2006, 07:20 PM   #3
Grumpy1
Grumpy1's Avatar
Both made in the same factory in Lafayette Indiana. Wanna make it a honda ? Slap a name badge on it. Only difference...
Old September 27th, 2006, 08:26 AM   #4
scottie
Eye candy
scottie's Avatar
yes i know, i was just being stupid and bumping it for you.
Old September 27th, 2006, 09:22 AM   #5
Grumpy1
Grumpy1's Avatar
thank ya. have one on me
Page generated in 0.26543 seconds with 39 queries
