2001 suburban lost steering - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 31st, 2011, 02:48 PM   #1
mideerslayer
NEVER GIVE UP!
mideerslayer's Avatar
Default 2001 suburban lost steering
I went to my son's school and on the way home went to make a right hand turn and the steering would not move. like it was locked. I could get it to turn enough to make a very wide turn.
So I get it home and I take off the power steering cap and there was pressure built up because it made a "air relief noise"
So I took the stick out and it smells burned.
The belt is still turning with no problems, so did the power steering pump go, or could it be the steering box?
If it is the power steering pump are they hard to replace?
mideerslayer is offline   Reply With Quote
Old October 31st, 2011, 03:23 PM   #2
LS1CJ5GIRL
I had a 5.3 pump break the shaft inside the pump.
LS1CJ5GIRL is offline   Reply With Quote
Old October 31st, 2011, 03:33 PM   #3
joescamaro67
joescamaro67's Avatar
Take the belt off and see if you can remove the pulley by hand.It will probly still have half the shaft on it
joescamaro67 is offline   Reply With Quote
Old October 31st, 2011, 03:56 PM   #4
mideerslayer
NEVER GIVE UP!
I will be tackling this tomorrow but by the sounds of your post it is the power steering pump?
Are they are to replace?
Old October 31st, 2011, 04:01 PM   #5
GREASYHANDS
GREASYHANDS's Avatar
Not hard, you will need a puller and installer to get pulley on and off.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 31st, 2011, 04:06 PM   #6
mideerslayer
NEVER GIVE UP!
How can I tell if I have hydroboost or vacuum boost?
Should I get the whole pump with the reservoir or can you just replace the "pump" or is it one of those things you cant tell until you take it apart
Thanks for all the help
Old October 31st, 2011, 04:45 PM   #7
s10v8zach
JACK STAND WHEELER
s10v8zach's Avatar
hydro boost systems will have lines going from the powersteering pump to behind the matser cylinder for the brakes.then return lines coming back and hooking up to the stering box. were vacuum brakes have a vacuum line going from a booster(behind master cylinder for brakes) to the back of the engine. hope this helps
s10v8zach is offline   Reply With Quote
Old October 31st, 2011, 07:33 PM   #8
mideerslayer
NEVER GIVE UP!
Can you replace just the "pump" and re use the reservoir? or is one of those things you have to wait and see what it looks like when you get it off?
Old November 1st, 2011, 05:23 PM   #9
mideerslayer
NEVER GIVE UP!
Well got it off and it sheared the shaft right off inside the pump.
Got the replacement and will finish installing tomorrow, takes a lot longer when you have back and neck issues, this thing called pain gets in the way
Page generated in 0.29618 seconds with 50 queries
