2002 chevy s-10 4.3 need help. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 28th, 2011, 08:58 AM   #1
trailrail302
Im going FAST!!!
trailrail302's Avatar
Default 2002 chevy s-10 4.3 need help.
I have a 2002 zr2 with a 4.3 The engine light was on and code said misfire. i changed the plugs, wires cap and rotor. Also checked compression on all cylinders when I did the tune up. The light went off for about 3 days. no it comes on intermitently usually is off at idle, once you start to drive and get up to about 30mph the light comes back on and will flash. code now reads random/multiple misfire. Any idea of where to go with this? anyone have a similiar problem? Also not sure if it is normal for these 4.3's but the oil pressure (when hot) will drop down to around 5-10 at idle and then up to about 40 when you are driving. Im sure the miss fire could be effecting some of that. It looks like the sending unit was replaced by a previous owner and the plugs/wires looked fairly new. I think I may be chasing the same problems the previous owner was chasing...lol Any help you be appreciated.
Thanks Dana,
trailrail302 is offline   Reply With Quote
Old October 28th, 2011, 09:01 AM   #2
IFS SUCKS
I like trees
IFS SUCKS's Avatar
What kind of tune up parts did you use?
IFS SUCKS is offline   Reply With Quote
Old October 28th, 2011, 09:04 AM   #3
trailrail302
Im going FAST!!!
I got everything from autozone and got the cheaper stuff. they had like 3 different prices for different brands etc. You think that could be part of it? I had another guy say that the cheap wires may be the cause.
Old October 28th, 2011, 09:08 AM   #4
trailrail302
Im going FAST!!!
oh also right after I did the tune up if you hammered it and put the truck under a load you could hear a fast ticking. (spark/arching sound) I thought it may just be a spark nock. but when it was doing that it never threw any codes. And I have not heard it since. When I did the tune up I put di-electric grease on the inside of the wires to help keep out moisture.
Old October 28th, 2011, 09:09 AM   #5
IFS SUCKS
I like trees
IFS SUCKS's Avatar
Gm cars don't like anything but gm plugs,and autolites are worse thing you can use in a Gm.
Old October 28th, 2011, 09:13 AM   #6
trailrail302
Im going FAST!!!
Hummmm I will have to look I think they may have been autolite.
If they are should I change to acdelco? I think thats a gm plug?
Old October 28th, 2011, 09:24 AM   #7
buttercr125
I work out
buttercr125's Avatar
Thats your problem right there!! Never buy ANYTHING from the zone.
X2
Definetley change them to ACdelco and put an ACdelco cap and rotor on it also.
Old October 28th, 2011, 09:31 AM   #8
trailrail302
Im going FAST!!!
X2
What do you think about the wires?
Man that sucks, Im sure I cant return that chunk now... I would have never thought it would make that much of a differnece.
I will look tonight to see what brands all this crap was.
Old October 28th, 2011, 09:43 AM   #9
kickstand
circling the drain
kickstand's Avatar
I had an O2 sensor cause a shit ton of misfire in my older silverado with a 5.3, replaced the o2 sensor and I was good to go.
Old October 28th, 2011, 10:17 AM   #10
trailrail302
Im going FAST!!!
was it throwing misfire codes?
Old October 28th, 2011, 02:51 PM   #11
Disturban
Disturban's Avatar
X2 use all ac delco parts, there is a reason gm used them on the assembly line, our bravada had 140k on it before I did the first tuneup and to be honest everything still looked pretty good.
Old October 28th, 2011, 03:06 PM   #12
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Check you distributer for play up, down, side to side, and check for slop. Easiest way is to just pull it and check the gear as its only one bolt. I went through the entire ignition system looking for my miss fire, and found a worn distributor gear to be my problem.
Old October 28th, 2011, 03:21 PM   #13
Mclovin
"The Situation"
Mclovin's Avatar
I can't tell you how many times ive installed autozone ignition parts and had to redo the job cause the parts are junk.. Toss in some delco plugs and some car quest wires rotor and cap. and i'd bet your problem goes away
Shit ill throw 5k casino cash on this bet
Old October 28th, 2011, 03:55 PM   #14
IFS SUCKS
I like trees
IFS SUCKS's Avatar
Yes this happened to my Tahoe as well,but mine never miss fired just quit running.
Old October 31st, 2011, 12:21 PM   #15
trailrail302
Im going FAST!!!
Ok I have delco plugs. Wires are Duralast and the cap/ rotor are truegrade. I put a coil on it this weekend. it runs strong. but light still comes on. I think I might replace the cap/rotor and wires and see what that does. if thats not it I think it might be the Cat.
Who knows, I think im going to sell the truck.
Old October 31st, 2011, 12:23 PM   #16
kickstand
circling the drain
kickstand's Avatar
yes sir
Old October 31st, 2011, 07:28 PM   #17
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
AC Delco parts only on the GM's.
Old November 8th, 2011, 12:29 PM   #18
trailrail302
Im going FAST!!!
I just read something that the belt tensioner pulley could cause this??? Mine has a bit of movement in it. (moves about 1/4" while it is running) This sounds very strange to me but could the random misfire have anything to do with the belt tensioner being bad?
Old November 8th, 2011, 12:39 PM   #19
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
well, most misfire algorithms look at changes in crankshaft acceleration - a belt tensioner jumping around *might* be enough... (?)
@clarkstoncracker
Old November 15th, 2011, 09:49 PM   #20
Toyfish
Toyfish's Avatar
Well for starters whoever told u it could be the belt tensioner is a retard and I've had this issue with a bout a half dozen customer vehicals and every time I fixed it by installing a new distributor
Page generated in 0.48803 seconds with 83 queries
