2nd gen dodge on tons re build - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 27th, 2011, 03:40 PM   #21
snocross2xtremes
snocross2xtremes's Avatar
got some upper and lower spring retainers built.
Name:	lower coil retainer.jpg
ID:	87275   Click image for larger version
Name:	upper coil retainer.jpg
Old December 29th, 2011, 08:01 AM   #22
snocross2xtremes
i need to order limit straps, shocks, bump stops.
im gonna run these for limit straps
http://www.sandparts.com/servlet/the...pension/Detail
not sure what shocks im gonna run yet..
as for bump stops im thinking set of Timbrens in side the coil spring.
http://www.timbren.com/index.htm
Old January 7th, 2012, 08:30 PM   #23
Offroadian
seasoned
Thought you were going to lower it?
Offroadian is offline   Reply With Quote
Old January 8th, 2012, 06:40 AM   #24
snocross2xtremes
The truck is 3 inchs lower then before..
Old January 8th, 2012, 05:59 PM   #25
Offroadian
seasoned
OK.
It don't look it.
My bad.
Old January 8th, 2012, 07:52 PM   #26
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
you should call this a buggy build
Old January 8th, 2012, 08:16 PM   #27
snocross2xtremes
OK.
It don't look it.
My bad.
Theres no motor I'n it right now
Old January 24th, 2012, 07:46 AM   #28
chevotass
chevotass's Avatar
no dummy. this would be a truggy. gawd your dumb sometimes
maybe i missed it. but all the trussing on the bottom side of the axle. is this so you dont bend it when jumping? when mudbogging isnt it best to have as little drag as possible. couldnt you have trussed the top and maybe just a couple small gussets on the bottom. and saved yourself from having a snow plow axle.
Old January 24th, 2012, 08:04 AM   #29
bigbchevy
missmrgreenagain
bigbchevy's Avatar
What do you know ?
H.o.r.e
Old January 26th, 2012, 12:44 PM   #30
snocross2xtremes
The reason for big bottom truss is because it's a cad ( center axle disconnect) axle and long side tube is very weak. Also with all the coil brackets it's hard to make a good truss on top to support the cad.
Old March 22nd, 2012, 11:09 PM   #31
snocross2xtremes
coil bucket gusset
Old April 25th, 2012, 11:36 AM   #32
snocross2xtremes
Motor is here!
the cage has been started...
TGW is in ten days!
Page generated in 0.27538 seconds with 60 queries
