Help! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 25th, 2006, 08:57 PM   #1
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
Default Help!
busted the tap inside one of the holes. to hard to drill into to get an easy-out into. any suggestions? i needHELP!!! its in the diff caseing one of the holes for the cover. i cant drill into the broken tap piece its to hard of metal. any ideas? i neeed help!
nate4d is offline   Reply With Quote
Old September 25th, 2006, 08:59 PM   #2
Is it flush with the cover? Big enough to weld a nut to it and turn it out?
Old September 25th, 2006, 09:00 PM   #3
nate4d
Gnarley Davidson
nate4d's Avatar
no its like 1/16 inside the hole and i dont have a welder.
Old September 25th, 2006, 09:05 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I would suggest a good pair of safety glasses and get a good punch & hammer. with out a torch to soften the metal you can shatter it and dig out the pieces. hit it in the center and rip the teeth off the tap and the center should break away and fall out after its shattered
Yetti
Old September 25th, 2006, 09:14 PM   #5
Immortal
NO RELIGION WAT!
Immortal's Avatar
Yep.....if you are lucky it is one of the through holes. Or you could simply do without if it is just one of the bolts.
Old September 25th, 2006, 09:22 PM   #6
95 Cherokee
95 Cherokee's Avatar
What about a carbide drill or end mill.
95 Cherokee is offline   Reply With Quote
Old September 25th, 2006, 09:27 PM   #7
Immortal
NO RELIGION WAT!
Immortal's Avatar
Could work, but likely will wallow out the hole first since I am sure he would have to use a hand drill.
I have had decent luck with this type of tap extractor. Not sure if you can see it, but it has 3 to 4 fingers that go into the grooves of the tap.
tap extractor
Old September 25th, 2006, 09:28 PM   #8
amc78cj7
amc78cj7's Avatar
It will be nearly impossible to drill out b/c it is hardened steel. They make tap removal tools that you might find on mcmaster-carr.com Or you can do like yetti said and put a narrow punch in the grove and slowly start tapping it out backwards. It sucks, I know. Next time make sure you only turn the tap maybe 3/4 turns before backing out and retapping to clean out the shavings and prevent this from happening again.
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Old September 25th, 2006, 09:31 PM   #9
Gunsworth
Gunsworth's Avatar
if it is just one, I would try puttin it together wit out it, might not need it. Especially if it is up top. lemme know if ya figure out how to remove it, I did this on one of the holes for my mirrors...
Old September 25th, 2006, 09:32 PM   #10
nate4d
Gnarley Davidson
nate4d's Avatar
GOT IT!!! with a punch and hammer! thanx to all.
im cleanin the old gasket off and bout to put the new one one and new cover
Old September 25th, 2006, 09:38 PM   #11
amc78cj7
amc78cj7's Avatar
Damn, that was fast. 35 minutes. Congratulations. GL4x4
Old September 25th, 2006, 09:47 PM   #12
84Scrambler
That tap extractor tool is freakin sweet. What does something like that cost?
Page generated in 0.23513 seconds with 58 queries
