93 Jeep Wrangler YJ - $4000 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 24th, 2011, 11:43 AM   #1
87HeavyChevy
87HeavyChevy's Avatar
Default 93 Jeep Wrangler YJ - $4000
93 YJ- $4000
4 cyl. 2.5 good oil pressure. good power. no smoke, leak or oil burn
Manual Trans - ax5 completely new clutch. pressure plate resurfaced. just had the gear oil changed
231 new SYE and CV rear shaft.
D30 new 4:88 gears. locked. (lunchbox) brand new brake pads, upper and lower ball joints and axle joints. just had the gear oil changed
D35 new 4:88 gears locked. (E Locker) just changed the gear oil.
rough country 4" springs. sprung under.
front drive shaft joints and straps are new.
frame is solid.
just had a cooling system flush.
heater and vents work as good as any other jeep. (does get warm in the winter)
33x12.5x15 stt's 85-95% tread (5 on rims)
wipers and pissers work as they should and has new wiper blades.
new steering column bearings.
brand new 3/4 ton steering upgrade.
all four shocks are new.
exhaust is new. the turbo muffler is a little louder than stock but not bad.
jvc cd player and kenwood speakers work good.
the bad:
rust hole on drivers side floor, easy fix. rest of the tub is solid including passenger side floor.
fuel and temp gauges don't work. includes a one gallon fuel can just in case.
when i bought it the guy told me the passenger side window comes off track when you roll it down. i don't know, i rolled it down and did get it back up.
Fixed- passenger side axle seal leaks a little.-Currently working on replacing the Axle Seal (8/15-new seal is in should be back together tonight 8/19-fixed).
rear window don't stay up on it's own.
Also Comes with a few hundred dollars worth of spare parts. Seats, Tcase (Don't know if it works), Engine (Haven't tried to turn it over), Can send a picture of all the spare parts on request.
ID:	84972   Click image for larger version
ID:	84973   Click image for larger version
ID:	84974   Click image for larger version
ID:	84975   Click image for larger version
ID:	84977   Click image for larger version
87HeavyChevy is offline   Reply With Quote
Old October 24th, 2011, 04:31 PM   #2
capndaveyj
looking for any trades?
capndaveyj is offline   Reply With Quote
Old October 25th, 2011, 02:14 PM   #3
87HeavyChevy
ATV with a plow, a nice pop-up... let me know what you have
I'm not looking for any projects.
Page generated in 0.24141 seconds with 33 queries
