83 ramcharger brake lights dont work - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 21st, 2011, 04:22 PM   #1
Jleach0696
Jleach0696's Avatar
Default 83 ramcharger brake lights dont work
83 ramcharger PO pulled wires out of column to rig the ignition and disabled turn signals and i think the brake lights are tied into it also, i plan on replacing the column when i have time was wondering if i could wire the brake light switch with a fused positiveon one side and straight to the brake light wire on the other
also was wondering which wire is the brake and which are the turn signals in the loom running to the rear lights
Jleach0696 is offline   Reply With Quote
Old October 21st, 2011, 06:29 PM   #2
Flat_Black
The Dodge Guy
Flat_Black's Avatar
best thing to do would be find a under dash wiring harness. trying to fix someones hack job sucks. iv had a few and it always ends up bad and blowing fuseable links.
Old October 21st, 2011, 09:48 PM   #3
Jleach0696
Jleach0696's Avatar
under dash is still good just the column wiring is torn into but the blinker lever flops around so i ll replace the column but i need brake lights till i get my check.
can i run a fused positive to one side of the brake light switch and connect the other side directly to the brake light wire that runs to the rear lights for a temporary fix and what size fuse would i use?
Old October 21st, 2011, 10:02 PM   #4
Flat_Black
The Dodge Guy
Flat_Black's Avatar
should be able to. i wouldnt run more then a 15amp fuse.
Page generated in 0.16236 seconds with 35 queries
