02 monte carlo - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 20th, 2011, 02:20 PM   #1
84ChevyMuscle
BigBoysNeedBigToys
84ChevyMuscle's Avatar
Send a message via AIM to 84ChevyMuscle
Default 02 monte carlo
Alright guys I'm in need of some serious help. I have an 02 monte carlo that has trouble starting. It starts most of the time and when it runs it runs well. My problem is thta every s often it won't start. It turns over but acts as if the fuel rail is shut off. I'm mechanical suited that I replaced the fuel pump, the plastic hardware the tublar sits in where the magnet passes through, the tublar, and reset the security lock. I was under the asumption that it was a security issue so at that point I took the car to an electrially capable car shop, where tey checked the bcm, pcm and bypassed the security lock by bypassing it. They all checked ok according to them so now I'm stumped. Could it be the icm? Any help would be appreciated, I'm stumped and sick of putting money into the car and nothve the problem fix
84ChevyMuscle is offline   Reply With Quote
Old October 20th, 2011, 02:33 PM   #2
84ChevyMuscle
BigBoysNeedBigToys
I forgot to say they had the problem happen to them also and checked the fuel pressure at the rail and it checked good too
Old October 20th, 2011, 05:24 PM   #3
wilesin
10ptbuck
wilesin's Avatar
Could be a crank sensor. Sometimes they get dirty and don't see that the crank is turning. When this happens the injectors will not work. If you have access to a scan tool watch the crank sensor signal while cranking the engine. If it does not show a signal as soon as you start cranking the engine over you have a problem. Good luck
wilesin is offline   Reply With Quote
Old November 15th, 2011, 10:28 PM   #4
84ChevyMuscle
BigBoysNeedBigToys
Replaced both crank sensors and spark plugs, and the car is still acting up. I wanna say its a sensor but when I took it to advance the only code being show was te egr vavle
Old November 15th, 2011, 10:42 PM   #5
Toyfish
Toyfish's Avatar
I had a similar issue 01 monte and it turned out to be the ignition switch
Old November 15th, 2011, 10:51 PM   #6
84ChevyMuscle
BigBoysNeedBigToys
I already replaced the ignition switch on it though, i feel as though im running out of options
Old November 15th, 2011, 11:32 PM   #7
84ChevyMuscle
BigBoysNeedBigToys
Alright so it just did it again, and this time i made sure I pulled a plug and I have spark so now all I need is fuel, what sensors or what will cause the fuel rail to be shut off
Page generated in 0.22180 seconds with 44 queries
