92 yj, "the mistress" - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 15th, 2011, 06:27 PM   #61
Grassman
2jz specialist
Grassman's Avatar
sooooo....
im planning on staying with leaf springs, here are my questions.
my understanding is that with wagoneer springs i keep the stock perches buy due to the pins i will gain 2" of stretch for the front and rear. total gain being a 4" stretch. others are trying to talk me into waggys in the front and xj's in the rear. what is the gain? havent found too much on that (i have 2 kids and a wife, ie little time to search every build thread possible)
i want to stay as low as possible, i dont care about the tub so trimming the crap out of it is no bog deal. what combination of springs should i be looking at? i would prefer to be able to find used springs if possible.
thanks for the help
Old December 15th, 2011, 06:45 PM   #62
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
What are the lengths and widths and pin locations of you stock springs? Maybe you can do something with those or we can figure out a different spring you can use.
Old December 15th, 2011, 06:51 PM   #63
Grassman
2jz specialist
Grassman's Avatar
From what I have found waggy's use yj mounts and give you 2" of stretch per end. That is the plan as of now unless people can shed light on the xj's for the rear. Also how much lift in the springs I will need
Old December 15th, 2011, 06:57 PM   #64
I want to say xj is 6" in the rear but not sure on the square headlight jeeps
Old December 15th, 2011, 06:57 PM   #65
I would think stock xjs would suck being they always sag horrible and ride shitty.
Old December 15th, 2011, 07:06 PM   #66
Erin had them on the back of his ride up until this spring without complaints. Probably worth talking with him at least.
Old December 15th, 2011, 07:23 PM   #67
bigyj
bigyj's Avatar
Erin was running YJ springs.
bigyj is offline   Reply With Quote
Old December 15th, 2011, 07:27 PM   #68
bigyj
bigyj's Avatar
The XJ springs will give you 6 inch stretch. You will want to add a leaf to them so they don't sag. Mine has stock waggies up front with the XJ springs rear with an add a leaf. You have seen mine. Not as low as I would like but not too tall either.
Old December 15th, 2011, 07:42 PM   #69
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
What about keeping the stock springs, move the pirches on the frame to the desired stretch and run a soa, cheap and easy. Looks like from my searching, nothing is a direct swap, at least to have it all right.
Old December 15th, 2011, 08:06 PM   #70
Grassman
2jz specialist
Grassman's Avatar
Tom, maybe I can swing over with a tape measure sometime?
Old December 15th, 2011, 11:03 PM   #71
Well there you go, my job here is done
Old December 16th, 2011, 10:11 AM   #72
bigyj
bigyj's Avatar
Yeah you can do that. Let me know
Old December 16th, 2011, 10:20 AM   #73
Grassman
2jz specialist
Grassman's Avatar
pm me your # and i will tyr to swing out
Old December 16th, 2011, 12:57 PM   #74
liv2mx
i like jungle gym's.
liv2mx's Avatar
i would stick with the stock spring also randy. they are easy to find and a little stronger then the xj springs.
Old December 16th, 2011, 01:11 PM   #75
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
And cheaper....
Old December 16th, 2011, 01:15 PM   #76
liv2mx
liv2mx's Avatar
make sure you build a good track bar or whatever you put back there will be twisted up like a pretzel.
Old December 16th, 2011, 03:24 PM   #77
Grassman
2jz specialist
Grassman's Avatar
problem is right now i have 3.5 lift springs i dont want to be that tall, and id like to get a lil bit of stretch to increase stability
Old December 16th, 2011, 03:59 PM   #78
Grassman
2jz specialist
Grassman's Avatar
http://www.wranglerforum.com/f8/wago...ft-118858.html
found some decent info
Old December 18th, 2011, 07:21 PM   #79
Grassman
2jz specialist
Grassman's Avatar
stoped out to bigyj's house (thanks tom) and got a plan. i will be running stock waggy's on all 4 corners and tweaking from there. if i just cant find waggy's i might ditch the lift springs and put stock springs back on.
this is going to be a stupid simple swap. i think i was just over thinking it.
Old December 18th, 2011, 07:56 PM   #80
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Looking forward to it.
Page generated in 0.26563 seconds with 83 queries
