10 Bolt Dana 44 Front ?'s - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 19th, 2011, 07:18 PM   #1
koochman450r
koochman450r's Avatar
Default 10 Bolt Dana 44 Front ?'s
I have an 87 chevy that the previous owner swapped in an older 10 bolt from a 3/4 ton like 80-81. I just broke both l/s shafts and r/s inner shaft. Question is will the shafts from a chevy 44 fit in it. Or any other 44 shafts.
you won this battle.
Old October 19th, 2011, 07:21 PM   #2
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
outers will inners won't. If you can't find them locally PM me I got a complete axle.
Old October 19th, 2011, 08:54 PM   #3
Ebrown
Ebrown's Avatar
I have a spare set in saginaw
Ebrown is offline   Reply With Quote
Old October 20th, 2011, 12:46 PM   #4
koochman450r
So why won't the inners work? Spline count? I believe they are both 28 spline. I might end up buying chromoly shafts after the new year but wanted something to get by with. Ebrown How much for the complete set of shafts?
Old October 20th, 2011, 01:39 PM   #5
spr_chicken
spr_chicken's Avatar
Send a message via MSN to spr_chicken Send a message via Yahoo to spr_chicken
The inners and outers should work. The splines should be 28. Unless you have a 1989-1991 10 bolt from a suburban or blazer then they are 30 spline. The only difference is the u-joint on a dana 44 is bigger. The dana 44 shafts will not fit throught the opening on the knuckle. You will have to remove the ball joints and install the shafts that way.
spr_chicken is offline   Reply With Quote
Old October 20th, 2011, 02:05 PM   #6
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
You can buy the complete kit brand new for $99 per side. Includes inner/outer/and u-joint. Motive gear brand 33% stronger than stock.
Old October 20th, 2011, 03:10 PM   #7
koochman450r
dang that sounds awesome. do you have a link bbb?
Old October 20th, 2011, 03:12 PM   #8
BigBlockBlazer
Axle breakin' 101
This is false, 10 bolts and GM D44's (and MOST other D44's) have the same 5-760x joint. All shafts are not made the same, and a bit of clearancing in the knuckle opening may be required.
Old October 20th, 2011, 03:13 PM   #9
BigBlockBlazer
Axle breakin' 101
http://www.nationaldrivetrain.com/GM...-CAR-ONLY.html
If you go to "axles" at the top left you will find the other side as well.
Back when I was 10 boltin' it I ran these and they performed well.
Old October 20th, 2011, 03:40 PM   #10
koochman450r
thanks i searched motive gears website and they only listed 30 spline. I'll be ordering these next week. Thanks man.
Old October 20th, 2011, 05:48 PM   #11
spr_chicken
I dont know what the difference is then but they dont fit unless you remove the knuckle... 10 bolt axles slide right into a dana 44 knuckle but the dana 44 axles will not fit through the 10 bolt knuckle. You would have to grind a good bit away to get the dana 44 shafts in.
Old October 22nd, 2011, 09:59 PM   #12
koochman450r
alright well i pulled the axle shaft out and its 30 spline. He said it was out of an early 80's 3/4 ton cuz it is 8 lug. Maybe its because it has an ARB in it he got the 30 spline for more strength. Either way i'll look for some 30 spline shafts now.
Old October 22nd, 2011, 10:22 PM   #13
ChevyRacer1981
D44 are 30 spline 10 bolt are 28 or 29 spline inners IIRC
Old October 23rd, 2011, 10:11 PM   #14
BigBlockBlazer
Axle breakin' 101
10 bolts are 28 or 30 in the front inner.
Old October 23rd, 2011, 11:25 PM   #15
koochman450r
yes but only 89-91 k5 and suburbans were factory 30 spline front. Did they ever make dana 44s that are not flat top passenger side knuckles. I thought all 44 were and the 10 bolts werent. I need to scrape the mud off and see if it has the 44 markings on it so i know. Or take some measurements on the shafts and compare them. thanks for the help guys.
Page generated in 0.28971 seconds with 68 queries
