my new fj-40 family truckster - Page 21 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 10th, 2013, 08:54 AM   #401
joescamaro67
joescamaro67's Avatar
Originally Posted by chevotass View Post
So did the broken spring fall out when u took the pump out?
If I remember right it was under a set screw. So no It didn't just fall out.
But when I looked into it at the time it was a common problem for the 5.3 and the 6.0L
joescamaro67 is offline   Reply With Quote
Old July 10th, 2013, 09:00 AM   #402
I was asking nick
Get your posts in sequence.
I thought it odd you would ask me.
Old July 10th, 2013, 09:18 AM   #403
PRV spring broke? rut rogh raggy!
Old July 10th, 2013, 09:55 AM   #404
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Didn't you just swap the oil pan and pickup to the LS4 pan?
Originally Posted by Google
Hey I just wanted to pass this on to you guys. 90% of oil pressure issues Ive found on these 6.0 engines is the O-ring between the oil pump & pickup tube..They deteriorate or sometimes are partially torn from factory ..This causes low oil pressure due to air getting pulled in with the oil..
and the same talk on pirate http://www.pirate4x4.com/forum/chevy...-start-up.html
Old July 10th, 2013, 11:00 AM   #405
Trailrig
Hoggin'-N-Boggin'
Trailrig's Avatar
Send a message via AIM to Trailrig
Thanks pirate!
Trailrig is offline   Reply With Quote
Old July 10th, 2013, 11:00 AM   #406
I hope that's all it is.
Old July 10th, 2013, 11:23 AM   #407
chevotass
chevotass's Avatar
Yep i did switch pans. And it happened right after. This seal thing would make sense
Old July 10th, 2013, 11:28 AM   #408
joescamaro67
there are 3 different O Rings also for the different pickups !!
Old July 10th, 2013, 11:34 AM   #409
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Here's the part number for the seal for the 2009 impala SS LS4. The same seal also comes with the pickup.
Seal, Oil pump 12584922
Old July 10th, 2013, 12:00 PM   #410
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
H'mm my 5.3 seems funnay when started after sitting. After reading the pirate link, it still seems like it would be easier to drop just the pan to replace this o-ring? Of course, that guy wanted to do a pump also. I would probably just repair the tube.
RIP FULLSIZE4LIFE
Old July 10th, 2013, 07:21 PM   #411
chevotass
chevotass's Avatar
gonna hit the dealership for the right o-ring tomorrow. hoping and praying to the wheeling gods that's all it is.
Old July 10th, 2013, 07:25 PM   #412
jhnyquest
goof ball
jhnyquest's Avatar
Here's to Hopeing.
Old July 11th, 2013, 05:50 PM   #413
chevotass
chevotass's Avatar
Fawk yesss▀▀ssssssssssssssssssssssssssssssssssssssssss
Old July 11th, 2013, 06:22 PM   #414
dreezy
Haggard Fab
dreezy's Avatar
O ring was a Weiner?
Old July 11th, 2013, 06:26 PM   #415
jhnyquest
goof ball
jhnyquest's Avatar
Sweet
Old July 11th, 2013, 06:40 PM   #416
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I will send you the bill.
Old July 11th, 2013, 08:15 PM   #417
chevotass
chevotass's Avatar
you the man JJ
Old July 11th, 2013, 08:20 PM   #418
chevotass
chevotass's Avatar
well. hit up the dealership today. $8.65 later I had a new o-ring. came home and pulled the pan and sure enough. torn up o-ring. popped the new one on. bolted everything back up. dumped in some oril. psi shot right up to 50. drove around for 30 minutes and its running great.
huge thanks to everyones input and links to save me from spending a lot more money.
now onto the next issue. the ls4 oil pan I bought off ebay is leaking. right in the middle of the pan. it must have a hair line crack or something. I can wipe the pan clean. then I slowly watch it bleed thru. its kinda creepy.
bad o ring.
Old July 11th, 2013, 09:12 PM   #419
Great to hear Nick. (about the o-ring, not the pan)
Old July 11th, 2013, 10:01 PM   #420
montecarlo33
The Violator
montecarlo33's Avatar
Which o ring did you order? Stock 6.0 or the one that goes with the pan?
Powered by: vBulletin, Copyright ę2000 - 2012, Jelsoft Enterprises Ltd.
Page generated in 0.40147 seconds with 84 queries
