my new fj-40 family truckster - Page 20 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 8th, 2013, 11:20 PM   #381
1 ton tj on 40's
1 ton tj on 40's's Avatar
will this be ready for the aug 9th? going to make plans to take my boy.
Old July 9th, 2013, 07:10 AM   #382
Originally Posted by chevotass View Post
unbolted the torque converter. inspected flex plate as best I could. I see nothing wrong. ohhh sooo sad
It was running fine before hand?
Old July 9th, 2013, 07:43 AM   #383
bigbchevy
missmrgreenagain
bigbchevy's Avatar
aug 3rd is the pig roast nick
H.o.r.e
Old July 9th, 2013, 05:06 PM   #384
chevotass
chevotass's Avatar
gonna try my best. need to find a cheap replacement 6 liter to put in. then ill tear mine down this winter and find out what went wrong and build it up to replace the cheap one.
Old July 9th, 2013, 05:17 PM   #385
Shitty.
Old July 9th, 2013, 07:07 PM   #386
Contact 2fst4u. He probably has a line on a 6.0 or 5.3 or 4.8 and probably a dozen other options.
Old July 9th, 2013, 08:15 PM   #387
chevotass
chevotass's Avatar
no matches for that name. are you referring to the fella with the yellow tj in his avatar from white lake?
Old July 9th, 2013, 08:31 PM   #388
jhnyquest
goof ball
jhnyquest's Avatar
That sucks
Old July 9th, 2013, 08:53 PM   #389
Yes, sorry for the misspell.
4.7 stroker or 5.3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 9th, 2013, 08:58 PM   #390
chevotass
chevotass's Avatar
holy crap that's a long thread. so were you playing a joke on me mr...
Old July 10th, 2013, 05:41 AM   #391
Old July 10th, 2013, 06:16 AM   #392
chevotass
chevotass's Avatar
pulled the pan. no signs of metal failure in the bottom. no clogged pickup. put the pan back on. filled it back up with oil. fired it up. at idle its showing 0-10lbs pressure. and I was hearing a ticking on the top end of the motor. I only let it run for a minute before shutting it off.
can an oil pump go bad?? or is it just fucked and I needs a new go faster thingy a doodle.
Old July 10th, 2013, 07:37 AM   #393
Mr.Green
I can levitate!
Mr.Green's Avatar
Put a Turbo Hyabusa motor in it. That would be sweet in your Jeep.
Old July 10th, 2013, 07:47 AM   #394
Wiped cam bearing or popped lifter bleeding out?
Old July 10th, 2013, 08:10 AM   #395
I doubt it's the pump. GM engines all seem to tick when first started so that's not really telling you anything. Low oil pressure is.
John, I wouldn't think a wiped cam bearing would knock like he first explained.
Old July 10th, 2013, 08:29 AM   #396
I was thinking along the lines the low oil pressure causing the knock. The cam bearing causing the low oil pressure.
What yr is your 6.0L and application it came from?
Old July 10th, 2013, 09:21 AM   #397
Mine? 2003 Escalade. No you can't have it. :
Old July 10th, 2013, 09:26 AM   #398
joescamaro67
joescamaro67's Avatar
My 5.3 lost oil pressure and started knocking shortly after I put it in.
Ended up being the pump. theres a spring loaded valve in them and the spring broke. Not saying that's your problem but it was mine. If theres no metal in the oil its hard to believe a cam bearing spun. Those make a lot of bling
joescamaro67 is offline   Reply With Quote
Old July 10th, 2013, 09:45 AM   #399
chevotass
chevotass's Avatar
So did the broken spring fall out when u took the pump out?
Old July 10th, 2013, 09:52 AM   #400
I was asking nick
Page generated in 0.36849 seconds with 85 queries
