TBI SBC- CEL 33, high map voltage issues - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 25th, 2006, 12:50 PM   #1
Bones
Bones's Avatar
Default TBI SBC- CEL 33, high map voltage issues
My jeep is running pretty good, but once an hour or so while wheeling it will stall.
If I have the trans in D or R with my foot on the brake hard enough that the vehicle is stopped, idle will drop real low and basically stall. If it gets low and I drop the trans into N, the RPM will climb back to normal almost instantly.
The CEL will come one when the idle goes low, as code 33, high MAP voltage. When idle comes back up, the light turns off.
Replaced the MAP sensor, does the same thing no matter what. If I disconnect the map vac line and plug it, and plug the map sensor port, the same code 33 comes up, which makes since. Basically when the Jeep goes too low of an idle, it doesn't create any vaccuum and sets the code. Same thing if I plug the hose so there isn't any vaccuum at all.
Any guesses? I'm not sure if my gearing and or hyd assist has anything to do with it or not….
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old September 25th, 2006, 08:18 PM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Put a manual vac guage in line whith the map and see what happens when you get the error. It's probably looking at TPS and seeing there's a huge (i'm guessing) load with no throttle. Load goes away in N.
@clarkstoncracker
Old September 25th, 2006, 08:57 PM   #3
Do you have VSS hooked up?
Old September 26th, 2006, 09:32 AM   #4
Bones
Bones's Avatar
I hooked it up kast night.
Its the painless VSS with 2 white wires, neither of them marked. Does it matter which one goes to signal and which goes to ground?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old September 26th, 2006, 10:13 AM   #5
Dunno. I just asked, because I know that can cause the stumble/stall when stopping.
Old September 26th, 2006, 10:34 AM   #6
Bones
Bones's Avatar
i just called them, it doesn't matter which wire is signal and which is ground... we'll see it that helps my issues.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Page generated in 0.19743 seconds with 41 queries
