Anyone heard about the new Warn . . . - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 25th, 2006, 12:36 PM   #1
Smiley
Smiley's Avatar
Default Anyone heard about the new Warn . . .
Warn Winch / Air Compressor combo product? I can't find anything about it on their website. Our company and Warn is owned by the same parent corporation and our CFO was talking about their new product. He had toured the Warn plant and saw them assembling this combo, he said it was selectable between using the motor for the winch and for the air compressor and it all fit under a nice die cast cover. He said it also had a cooler before the air chuck so the chuck would not burn your hand after extended use like some of the other compressors out there.
I found info on it here - Warn PowerPlant Dual Force
http://winchcentral.com/catalog/prod...6ada156c418deb
But it doesn't mention the compressor duty cycle.
Smiley is offline   Reply With Quote
Old September 25th, 2006, 12:40 PM   #2
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
I know it is in the $1400 range. Quadratec had it on their website.
Old September 25th, 2006, 12:45 PM   #3
yellowjeeperman
The N3rd
yellowjeeperman's Avatar
oOo sexy! that is nice!!!
yellowjeeperman is offline   Reply With Quote
Old September 25th, 2006, 12:46 PM   #4
Bleay
sick of jackstand wheelin
Bleay's Avatar
That is cool. I want one
Bleay is offline   Reply With Quote
Old September 25th, 2006, 12:53 PM   #5
Bones
Bones's Avatar
so what if the compressor turns on when you're doing a water crossing or splashing through the puddles?
I'de say cool idea for a tow rig, probably not for a trail machine
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old September 25th, 2006, 01:00 PM   #6
Icemanii
GLFWDA Land Use Committee
Icemanii's Avatar
What would cause it to turn on? Looks to me like you have to select compressor to make it work.
Anyone know what size the winch is? I don't think I saw it on the site.
Icemanii is offline   Reply With Quote
Old September 25th, 2006, 01:02 PM   #7
Bones
Bones's Avatar
I assumed it could be controlled like any compressor to keep a tank at a set level, then use that tank to run tools, lockers etc.... I have read other places that the winch doesn't have the CFM to run most tools or lockers, so it has to deliver the air to t atank where it would be used.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old September 25th, 2006, 01:06 PM   #8
jeepfreak81
81 inches of fun
there is a 9500lb version and a 12,000 lb version
http://www.quadratec.com/products/pr...&mn=Warn&c=142
The new PowerPlant Dual Force is flat out the most versatile product to hit your vehicle this year. This multi-purpose performance tool blends a top-end winch, and a high-end air compressor—in one space-saving on-board unit. Flip the activator switch to air compressor and discover the PowerPlant’s can-do attitude. It puts out 12 cfm @ 0 psi, with a 1/2 gallon storage tank. That translates to airing up four 35” tires in 8 minutes. Which is just one way to put the PowerPlant to work. It tackles everything from inflating a whitewater raft to running a nail gun.
Switch to winch mode and the PowerPlant turns on the legendary WARN winch technology. You get the raw pulling power of a Gen II Series Wound motor. Plus the proven reliability of the 3-stage planetary gear train. In other words, WARN to the rescue, time after time. The PowerPlant Dual Force comes with air hose and fittings. Additional air compressor accessories are available (such as larger air tank needed for some power tools).
# 9,500 lbs. maximum rated pull (single line)
# Fast line speed of 26.9 feet per minute (no load), 5.2 feet per minute (at 9,500 lbs. max load)
# 125 feet of 5/16” wire rope
# 12,000 lbs. maximum rated pull (single line)
# Over twice the duty cycle of the HP under heavy load
# 80 feet of 3/8” wire rope
Old September 25th, 2006, 01:15 PM   #9
Mongo
Mongo's Avatar
http://www.greatlakes4x4.com/showthread.php?t=21080
Mongo is offline   Reply With Quote
Old September 25th, 2006, 01:35 PM   #10
Paul04TJ
Small, but talented
Paul04TJ's Avatar
Originally Posted by dads95yj
Damn I wanted to finally get the repoast!!!!
Paul04TJ is offline   Reply With Quote
Old September 25th, 2006, 01:53 PM   #11
Smiley
Smiley's Avatar
I'll bet I'm not the only one that doesn't visit that forum.
Old September 25th, 2006, 02:07 PM   #12
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
i too dont think it wont fit my ARB bumper I like the idea, but wonder how high the combo is? I think id rather keep my 9.5si and my yoke/kilby OBA.
I'm the man in White.
Old September 25th, 2006, 02:37 PM   #13
Lothos
KD8GKB
Lothos's Avatar
Um, how/why would an air chuck get hot from use? They usually get very cold on me.
Old September 25th, 2006, 02:38 PM   #14
Mongo
Mongo's Avatar
I wasn't meaning to say repoast, just adding info. It's still open for you.
Old September 25th, 2006, 02:42 PM   #15
MozMan68
Poseur Extraordinaire
MozMan68's Avatar
Default mmmmmmmm
aarrrrrrrggggglllllllll......muuuuust haaave Warn wiiiiiinch.......
MozMan68 is offline   Reply With Quote
Old September 25th, 2006, 02:42 PM   #16
jeepfreak81
81 inches of fun
I have burned my hand one one before, usually when your doing high volume stuff, running a tool constantly for a long time. I think it was an air nailer the last time.
Old September 25th, 2006, 02:47 PM   #17
Lothos
KD8GKB
Lothos's Avatar
I was using my framing nailer all day yesterday and it was basically ice cold. Same with a die grinder. That's why this is cionfusing me.
Old September 25th, 2006, 02:50 PM   #18
Go grab the pipe from between the compressor and the tank, then you'll answer your own question.
Old September 25th, 2006, 03:08 PM   #19
Lothos
KD8GKB
Lothos's Avatar
Ahh, yes...that part is hot :) But the cliff notes don't mention THAT. That of course is the reverse effect of the pressure effect.
Old September 25th, 2006, 03:22 PM   #20
bj house
bj house's Avatar
Which is how those cold air guns work right ...
Page generated in 0.32308 seconds with 82 queries
