Another won't start story... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 16th, 2011, 07:44 PM   #1
3stratman
Let's Go Red Wings!
3stratman's Avatar
Default Another won't start story...
Problem with my '03 Hemi Ram.
This happened 2 or 3 times previously, but only for a minute or two. Now it has happened and it seems to be for good. I get in the truck, put in the key and turn to auxiliary/start. Radio comes on, but no cluster/indicator lights, no gauge movement, and no turning over at all. All electrical items work- odometer coming on when door opens, lights all work ( interior, brakes, headlights, dash lights), radio works. The first couple of times this happened, I would turn the key off and on several times, and the cluster/indicator lights would finally come on and the truck would start. The last time previous to this, the same thing; only this time I shifted into neutral, then turned the key. The indicator lights finally lit and the truck started- might have just been coincidence. Now the indicator lights will not come on at all and no starting. Everything electrical still works fine, radio, headlights, dash lights, brake lights, interior. Just no indicator lights in auxiliary/start position, no gauge movement, and no turning over at all.
My guess is something is bad in the ignition module in the steering column. Anyone had this problem before? And is it something I can fix myself, or am I headed to the dealer?
3stratman is offline   Reply With Quote
Old October 16th, 2011, 07:49 PM   #2
GREASYHANDS
GREASYHANDS's Avatar
Sounds like a bad ignition switch. Swapping it out shouldn't hard with the proper tools.
Before you decide to throw parts at it check the connections under the power distribution center for corrosion. I have seen several of these trucks with similar problems, make sure to look for loose wires as well.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 17th, 2011, 10:05 PM   #3
tweak177
Say what?!?
tweak177's Avatar
x2, check for corrosion, it's likely the ignition switch but peeking around is free! Good luck
tweak177 is offline   Reply With Quote
Old October 17th, 2011, 10:22 PM   #4
buttercr125
I work out
buttercr125's Avatar
Never head to the stealer....I can help you out if need be. PM me a phone number if you need some additional help. It will be tomorrow sometime before I call you though because I am heading to bed now.
Page generated in 0.23508 seconds with 35 queries
