were is that vagina joescamaro build? - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 9th, 2011, 09:53 PM   #81
joescamaro67
joescamaro67's Avatar
Well I thought i had my voltage problem fixed but it`s still not right
After wiring my fan in today i fired it up and since i ran the battery down a little bit the gm alternator is putting out more than the jeep ecm wants to see. Basically the jeep computer hasa actual voltage and desired voltage when the gm alternator puts out more than the desired voltage my gauge goes full bore and check gauges light comes on.So who on here is good with automotive electrical. How can i make my internally regulated alternator not put out any more than like 13.4-13.5 volts.Or can I put a resistor before my jeep computer to make it think it only has that voltage?
joescamaro67 is offline   Reply With Quote
Old November 9th, 2011, 10:03 PM   #82
buttercr125
I work out
buttercr125's Avatar
I am good..well ok, I am great with electrical. I would think the best way to go about it would be change the programming in the PCM. I need to read back through the thread but do you have a stand alone pcm for the engine or did you have the factory pcm programmed and get a wiring harness to plug into it?
Old November 9th, 2011, 10:16 PM   #83
joescamaro67
The gm is a stand alone system.the jeep computer thinks that the 5.3 is the 4.0 liter running the problem is that the jeep computer tinks it can still control the alternator and it cant the gm is regulated on its own. Can i have the jeep computer reflashed to get ri of the desired voltage and is the jeep pcm the problem or is it the processor in the cluster that tells the needle to peg?
Old November 9th, 2011, 10:41 PM   #84
buttercr125
I work out
I will check it out tomorrow and let you know. A couple questions though.
1. What year is your jeep?
2. So the GM pcm is controlling the alternator correct?
3. What year is the engine and GM pcm you put in?
4. Who made the stand alone harness?
Old November 9th, 2011, 10:44 PM   #85
joescamaro67
2- kinda the gm computer just tells the alternator to turn on
3-2002 suburban
4- Novak
Old November 9th, 2011, 11:01 PM   #86
tw1st3d5
tw1st3d5's Avatar
Flashing and Jeep ECMs don't exist together in the same sentence from what I've heard. Have you searched through the 5.3 thread on pirate? Lots of good info in there. I'll take a look in a little while and see if I can find something for you.
Old November 10th, 2011, 06:35 PM   #87
liv2mx
i like jungle gym's.
liv2mx's Avatar
after seeing all the wires you cut out ...if you cant figure it out i will be shocked!
me and mike will be over in a half hour to hold your hand.or i mean watch you try to figure it out.
Old December 6th, 2011, 11:25 AM   #88
liv2mx
liv2mx's Avatar
so post some pictures of your finished product. this thing looks like it came with a 5.3. he did one hell of a nice job.
so did you get the iroks or the krawlers?
Old December 6th, 2011, 12:02 PM   #89
dmoney
tj on 36 iroks
dmoney's Avatar
Location: fremont michigan about hour north of grand rapids
well just in case you wanted my 2 cents i was having all kinds of problems with my volt gauge pegging out i when out and bought a new(used) computer thinking that would fix it because my jeep is completely stock motor wise....ended up being my batterie it would still start my jeep everytime but it was drained down enough that my computer would tell the alternator to charge at 19 volts it even fried my alternator before i figured it out.........i know its a bit different but my be worth a shot just to throw the batterie out of the daily driver and see what it does?
dmoney is offline   Reply With Quote
Old December 6th, 2011, 12:05 PM   #90
joescamaro67
The computer wasnt actually telling your to charge at 19 volts its set up that way to throw the idiot light when over charging more than 13.6 jeeps do the same thing backwards with no charge it drops the needle down all the way to throw the check gauges light it wont actually read low voltage.
Old December 6th, 2011, 12:14 PM   #91
liv2mx
liv2mx's Avatar
so you didn't answer my question.. wtf did you get for rubber.
Old December 6th, 2011, 01:17 PM   #92
joescamaro67
Default tires
40X13.5x17 Bfg Krawlers shipped out this morning and I ordered 5 this time so hopefully I`m not in this situation agian anytime soon . Let your shit talking begin.But remember mine runs And by the sounds of it I`m gonna be responsable for making yours run so Be nice
Old December 6th, 2011, 01:24 PM   #93
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Not going by the stock gauge, are you charging?
Old December 6th, 2011, 06:57 PM   #94
superduty03
superduty03's Avatar
I see you finally planted that $ tree I gave u..... I'm gonna get a tattoo that says "i wanna be Joe" on my forehead!
superduty03 is offline   Reply With Quote
Old December 7th, 2011, 11:55 AM   #95
liv2mx
liv2mx's Avatar
we need this joe..smoking deal...499.00 www.probender.com
Old December 7th, 2011, 01:41 PM   #96
joescamaro67
WE or I need this so you can borrow it?
Old December 7th, 2011, 03:16 PM   #97
chevotass
chevotass's Avatar
looks like joe has a stage 1 clinger.
Old December 7th, 2011, 05:57 PM   #98
superduty03
His personality can be very addictive.... Except for when he's a dick!
Honestly though, joe's heep is one of the cleanest builds I have seen, and has come together damn fast I might add.... Good job friend.
Old December 9th, 2011, 08:34 AM   #99
liv2mx
liv2mx's Avatar
i will be putting a order in after x mas.so you can borrow.
Old December 9th, 2011, 08:35 AM   #100
liv2mx
liv2mx's Avatar
now if we can just get some dents in that thing.
Page generated in 0.48647 seconds with 84 queries
